Thread: Parking break light comes on?
Results 1 to 6 of 6
  1. #1 Parking break light comes on?
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    In the morning when i start up my car my parking break light comes on. I never use the parking break because i don't really trust it, it usually goes away once i break fairly hard, anyone have an idea why this might be? Car is a 99 gp gt
  2. #2 Re: Parking break light comes on?
    Maybe the park brake shoes are sticking or are moving around.
    I would take the rear brakes apart, clean up everything and throw em back together to see if its fix.
    Also check your brake fluid level, that can trip the light.
  3. #3 Re: Parking break light comes on?
    gardner,mass
    My parking brake light stayed on after working on my rear brakes untill i dc the battery to reset the pcm.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: Parking break light comes on?
    SWPA
    Low brake fluid will cause the light to come on.
  5. #5 Re: Parking break light comes on?
    Jun 2013
    Illinois
    Ok i will check the brake fluid next time i go out. thanks guys!
  6. #6 Re: Parking break light comes on?
    SE Level Member Thinksun's Avatar
    Sep 2012
    GTP Ontario
    Just fixed same symptom on friends car. In his case the float in master cylinder was stuck down and only needed a tap.
    1997 GTP .
  1. ABS and Parking Break Light On, and Key Sticks in Ignition
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 06-18-2013, 01:22 PM
  2. driver side parking light and fog light not working
    By shelbyguy04 in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2013, 01:37 AM
  3. Parking break goes to floor..Help...
    By MOTELETJR in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2013, 04:07 PM
  4. trac off light and parking break on
    By levisooy in forum General Tech Discussion
    Last Post: 04-24-2012, 10:37 PM
  5. break light
    By 1LoudGrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 09-08-2009, 04:09 PM
