had my stuff shipped to the states to save shipping and brokerage. Put them on during a road trip. 2 Borla Pro XS Mufflers, ZZP 2.5" 304SS Catted Downpipe, and some rounded dual tips.
Nice![]()
Might be pushing it close. SD don't seem to give to much room. A better choice would be Vinnie Spacers. What's the reasoning behind you wanting shorter dogbones? Are you lower?
You gonna give us a vid or what!
I'm not back home yet, and my good phone with 1080p video is in for service. I'll post as soon as I can!!
From the very limited driving I've done since getting it done I can tell you it's a lot deeper than stock, there is some drone but NOTHING compared to having a rotted out muffler and shot cat. It backfires after WOT pulls, and has a nice rumble at idle.
yessir, wasn't going to make the same mistake again. I once got rid of it on my 99 because it was cracked and it was one of the worst things I had ever done, SO MUCH RASP
if it occured after you put the cat in its probably the cat but it could possibly be the downstream O2 sensor giving a bad reading but obviously its more likely to be the cat. which ever the case get a simulator itl fix both problems and probably cheaper and faster than a tune.
I had a p0420 before I put any of the exhaust parts on. Had the parts put on, they reused o2s, cleared code and it was good for about a day.
Threw a p0420 on the new stuff after about an hour into my drive from Toledo to Toronto.
Just realized they don't make an o2 simulator for 04+![]()
Simulator don't work with the 04+. A cheaper and efficient solution is google spark plug fouler trick and goodbye po420 code.
