Thread: AC Air vents - Hot one drivers side - cold on passenger
Results 1 to 7 of 7
  1. #1 AC Air vents - Hot one drivers side - cold on passenger
    Jun 2013
    Orange County
    Hi: I have a 1999 Grand Prix GTP Supercharged. Dual AC control, auto temperature. With the AC on I get hot air on the drivers side, and cold on the passenger side. When I turn on the recirculate there is a noise from under the dash. With the heater on, both sides are hot and the recirculate is fine. I tried all "modes" in both heat and air, no problems. Shoot - the recirculate mode made noise- now I don't remember hot or cold! I have read that it could be the actuary door located on the drivers side, and can be accessed by removing the kick panel under the steering wheel...... I had a mechanic look at it and he said that the motor located next to the glove compartment was working just fine. Any ideas? BTW: I just replaced the AC unit/compressor a couple of weeks ago, it was blown out....but the vent issues were already there.....
  2. #2 Re: AC Air vents - Hot one drivers side - cold on passenger
    Check the drivers side blend door.
  3. #3 Re: AC Air vents - Hot one drivers side - cold on passenger
    Jun 2013
    Orange County
    That is the plan, from what I have been able to Google.... the blend door (actuary door) on the drivers side can be accessed by removing the kick panel under the drivers side.....is this correct?
  4. #4 Re: AC Air vents - Hot one drivers side - cold on passenger
    I think this has the info you want.
    http://www.grandprixforums.net/blend...ght=blend+door
  5. #5 Re: AC Air vents - Hot one drivers side - cold on passenger
    Jun 2013
    Orange County
    This helped. My mechanic looked in and said that the motor isn't changing or turning when changing the mode..... Also, I read in another post about getting code readings by holding down both driver and passenger AC controls for 5-10 seconds and then turn the drivers side for a code reading. I did this and it only reads "00"...if I turn the drivers side know then the numbers will scroll from 0-22 and start over.....What is the issue here?
  6. #6 Re: AC Air vents - Hot one drivers side - cold on passenger
    Sep 2011
    Copperas Cove, TEXAS
    Cut and pasted from the GM Manual:
    On-Board Diagnosis Mode
    The CJ2 air conditioning is equipped with an on-board diagnostic feature which allows the heater-A/C control to detect certain system faults. The diagnostic feature may also be used to display certain data parameters. If the heater-A/C control detects a fault in the system, the man symbol will flash during the first 2 minutes of vehicle operation.
    Entry into the diagnostic mode is gained by pressing in on both temperature knobs at the same time for 5 seconds. The following display modes are found within diagnostics:
    The diagnostic pointer
    The diagnostic value
    By rotating the driver temperature knob one detent in either direction, the display is toggled between pointer and value. The value displayed is the decimal equivalent of the RAM contents. A 2 is formed using the minus sign and the leading 1 in order to display values over 199.
    A diagnostic pointer mode is identified by a minus sign preceding the pointer number. The pointer provides an index, which identifies the corresponding diagnostic value. The diagnostic trouble codes (DTCs) reside under diagnostic pointer -00. The pointer will be set to this position upon initial entry into diagnostics. If more than one code exists, the codes will be displayed sequentially at a rate of 2 seconds per fault. Rotating the passenger temperature knob will switch the diagnostic pointers. A wrap around feature is provided if the pointer is continued past either end. Other data used by the computer resides under different diagnostic pointers, and may not be of use in observing the system. Press any mode button in order to exit the diagnostic mode.
    Important
    A 2-digit trouble code indicates the fault is current. A 3-digit trouble code indicates a history fault.
    Clearing Codes
    Press the A/C mode button in order to clear codes from the heater-A/C control.
    Any of the following components may cause malfunction in the temperature controls:
    The refrigerant system
    The electrical wiring connections
    The vacuum connections
    Faulty components that have mechanical problems, such as sticking valves
    As a part of the diagnostic process inspect the following components:
    The refrigerant, vacuum or mechanical systems. Refer to Vacuum Test .
    The blower controls. Refer to 66-0 .
    The compressor controls. Refer to Cell 67: RPO L36, L67 .
    The air delivery controls. Refer to Power and Grounds .
    The temperature controls. Refer to Electrical Diagnosis. Complete the diagnostic procedure for the heater A/C control microprocessor.
    Press and hold both the Driver and Passenger knobs in simultaneously until the display changes to read "-00". To change position, turn the Driver knob to the desired number and turn the Passenger knob one click to view the data for that position.
    Position Description US Observed on mine Canada
    -00 Error codes Click here for the Trouble Codes chart
    -01 (servo position) 103-107 43-162
    -02 (servo position) 128 120-202
    -03 (servo position) 150 162-194
    -04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed
    -05 (servo position) 93 88-191
    -06 (servo position) -152 00-252
    -07 (servo position) 00 0, 34-255
    -08 (servo position) -155 00-255
    -09 (servo position) 00 0, 23-255
    -10 ? 04 04
    -11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower
    -12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135°F
    -13 Actual Vehicle Speed in MPH
    -14 (servo position) 00 21=0
    -15 ? 39 44
    -16 Radiator low fan turn on temp -106 207
    -17 Radiator low fan turn off temp 196 199
    -18 ? 50 51
    -19 (servo position) 162-169 40-172
    -20 Affected by cabin temp sensor 89 50-172
    -21 (servo position) 00 ?
    -22 Sunload Sensor -117 LIGHT=126, 218=DARK
    To return to normal operation, press the MODE button next to the Passenger temperature knob.
    This is a list of the Trouble Codes displayed by the CJ2 Unit.
    A two digit code indicates a current fault while a three digit code indicates a historic fault.
    Trouble Code Description
    00 No System Fault
    01 or 101 Inside Air Temperature Sensor Short
    02 or 102 Inside Air Temperature Sensor Open
    03 or 103 Ambient Outside Temperature Sensor Short
    04 or 104 Ambient Outside Temerature Sensor Open
    05 or 105 LH Electric Actuator Open or Short
    06 or 106 RH Electric Actuator Open or Short
    07 or 107 UART Serial Data Line Fault
    08 or 108 Solar Sensor Open
    To clear codes from the CJ2 Unit, press the A/C Mode button.
  7. #7 Re: AC Air vents - Hot one drivers side - cold on passenger
    Jun 2013
    Orange County
    Thanks: I ran it twice - tried clearing but I don't think it worked: I got some codes that are not on your list......Note: Position followed by codes from two readings after attempt to clear ....1: 10,10 2:toggled between 95/96, 98, 3: 155, 155, 4: 00, 15, 5: toggled between 90/91, 89/90, 6: 154, -154, 7: 147, -154, 8:2, 0, 9: 149, -155 10:4, 4, 11:00, 02, 12:138, 137, 13: 00, 00, 14: 00, 00 15: 60, 60, 16: -115, -115, 17: 193, 193, 18: 49, 49, 19: 192, 192 20:111, -114, 21: 00, 00, 22:100, -106, and a third 189. Obviously the actuary door isn't functioning..... going to try and get the motor replaced this afternoon. Thanks....Debra
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. '04 GTP Comp G - Blower/ HVAC issue / Hot Drivers Cold Passenger
    By KKli23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 08:32 PM
  3. Passenger side cold. Driver hot?!
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 05-31-2011, 07:49 PM
  4. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  5. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
