Okay so in the 97 gtp there are 3 parts of the evap system:
1. The evap canister purge valve
2. The evap canister
3 The evap switch ( only in the 97 to my knowledge )
I removed the the the purge valve and I am using the evap that comes stock on the gen V blower.
The hoses are going from the evap on the gen v to the switch which is then connected to the canister, like so:
Do you see the third hose with the 90* bend in it that isnt connected to anything? What should it be connected to? Do I even need the switch?
Next question,
Because I had a 97 blower with the extra vac tree, like so:
Do I need to run the vac hoses like this now that I have the genV blower?
In other words, do I need to connect a hose from the nipple on the lim under the sc snout to the fuel rail?
