Thread: 97 evap/vac route to genV routing
Results 1 to 20 of 20
  1. #1 97 evap/vac route to genV routing
    Howell, NJ
    Okay so in the 97 gtp there are 3 parts of the evap system:
    1. The evap canister purge valve
    2. The evap canister
    3 The evap switch ( only in the 97 to my knowledge )
    I removed the the the purge valve and I am using the evap that comes stock on the gen V blower.
    The hoses are going from the evap on the gen v to the switch which is then connected to the canister, like so:
    Do you see the third hose with the 90* bend in it that isnt connected to anything? What should it be connected to? Do I even need the switch?
    Next question,
    Because I had a 97 blower with the extra vac tree, like so:
    Do I need to run the vac hoses like this now that I have the genV blower?
    In other words, do I need to connect a hose from the nipple on the lim under the sc snout to the fuel rail?
  2. #2 Re: 97 evap/vac route to genV routing
    Howell, NJ
    Im thinking maybe this should be moved to general tech.
  3. #3 Re: 97 evap/vac route to genV routing
    Easiest way to do this is hook the evap line to the Gen V evap, hook the evap purge soleniod electrical to the Gen V evap soleniod and kill the code for the switch. The switch was a goofy secondary way that GM held it back etc. In 98 they didn't use the second piece and things worked well.
  4. #4 Re: 97 evap/vac route to genV routing
    Howell, NJ
    So what your saying, basically remove the switch. Then connect the evap line coming from the evap canister to the genv evap.
  5. #5 Re: 97 evap/vac route to genV routing
    I don't see it in your pic..but I assume the evap soleniod is in your gen 5 still. Hook the line to it.. then the connector and poof..
    That's what I did on my 97 Bonne
  6. #6 Re: 97 evap/vac route to genV routing
    Howell, NJ
    Lol what line? The one from the switch or straight from the canister ?
    As of now it's going canister>switch>genv evap. With the connector in the genv evap
  7. #7 Re: 97 evap/vac route to genV routing
    That shoudl work too..
    I'd run from tank to evap.. done. Dump switch. Taht's me though.
    and FWIW that extra 90 degree elbow..it goes no where. It's a vent
  8. #8 Re: 97 evap/vac route to genV routing
    and...GM only used this goofy setup in 96 and 97. W bodies didn't really get the 3.8 in 96 though, so most of you wouldn't have come across it.
  9. #9 Re: 97 evap/vac route to genV routing
    Howell, NJ
    Okay cool. I was just thrown off by the switch and the extra hose.
    Now one more question, do I need to put a T on the vac source under the sc snout and fpr then connect the two?
    oor can it stay like it was when I had the 97 blower.
  10. #10 Re: 97 evap/vac route to genV routing
    You need a t on the under snout to feed the map sensor and the fpr, plus the boost soleniod if you have it.
  11. #11 Re: 97 evap/vac route to genV routing
    Howell, NJ
    Okay, the way I have it now it's just the fpr connected to the boost solenoid.
  12. #12 Re: 97 evap/vac route to genV routing
    sooo where's the vacuum source?
  13. #13 Re: 97 evap/vac route to genV routing
    Howell, NJ
    I dunno it seemed to be working so I didn't question it at first.
  14. #14 Re: 97 evap/vac route to genV routing
    Quote Originally Posted by Jomamma View Post
    haven't we been over this already? dont make me come down there lol
  15. #15 Re: 97 evap/vac route to genV routing
    Feb 2013
    37.295091, -121.930053
    think he wants you too scotty lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  16. #16 Re: 97 evap/vac route to genV routing
    Howell, NJ
    you caughgt me. I was just a little confused
  17. #17 Re: 97 evap/vac route to genV routing
    Well...ask because you don't wanna have Scotty standing over you with me on the phone. Ask Greg..it's not pretty.
  18. #18 Re: 97 evap/vac route to genV routing
    i remember that one.
  19. #19 Re: 97 evap/vac route to genV routing
    Feb 2013
    and scotty is a very HUGE guy he stands in at 6 foot 6 inches and has huge arms.
  20. #20 Re: 97 evap/vac route to genV routing
    Howell, NJ
    Okay well it's all hooked up now... And with out using ugly T's
  1. Replies: 4
    Last Post: 07-22-2012, 07:21 PM
  2. ZZP SS kit... belt routing?
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2012, 10:26 AM
  3. L67 vacuum routing HELP!
    By thunder71173 in forum General Tech Discussion
    Last Post: 04-02-2011, 06:33 PM
  4. Which route to go next?
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2010, 06:43 PM
  5. hello from route 66!!
    By sideshow elvis in forum Introductions/Noob Questions
    Last Post: 06-27-2009, 12:59 PM
