Thread: removing plug wires
Results 1 to 6 of 6
  1. #1 removing plug wires
    Jun 2012
    Southern NJ
    Is there some trick to getting these damn things off? I swear they're held on by the strength of He-Man himself.
  2. #2 Re: removing plug wires
    SE Level Member evand's Avatar
    Jun 2013
    United States
    Get plug pliers
  3. #3 Re: removing plug wires
    put some leather work gloves on, then twist and rip em off, if your changing them it dont matter if you tear them up or not.
    pulling the dog bone bolts off the engine then pulling the engine forward and locking it there with the left side dog bone mount second hole in the bracket, or ratchet strap the engine forward, this adds some room to work on the rear plugs.
  4. #4 Re: removing plug wires
    Jun 2012
    Southern NJ
    front head is already off, so I sorta ratchet strapped it forward using the EGR bracket since I'm ditching that anyway (lol emissions). I got one of 'em off, but I'm still ripping on the rest.
  5. #5 Re: removing plug wires
    Apr 2012
    Goderich, Ontario
    Use dielectric grease when you install the new wires. Just keep twisting left and right, push and pull, they'll come off.
    -Paul Walker
  6. #6 Re: removing plug wires
    GT Level Member Shiftingshaddow's Avatar
    KC
    you can cut them with a utility knife along the boot. then i think i just used a pick tool to pull the metal connector off. or it might have just fell off. i cant remember. i just know i tore one of them and had to cut the rest off the plug with a knife.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  1. MSD plug wires?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 05:39 PM
  2. Best plug wires??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 06-06-2010, 07:34 AM
  3. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  4. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
