Thread: Key fob
Results 1 to 9 of 9
  1. #1 Key fob
    Mar 2013
    ny
    Hey I bought 97 gp and came with the fob I tried to work it but no luck I tried to reset it like the manual says too. How do I tell If the car has a transmitter. Does the trunk have codes on that sticker
  2. #2 Re: Key fob
    Aug 2012
    westlock alberta
    what brand is the fob? as far as i know 97 never came with remote anythings but dealerships would install viper systems but if its aftermarket its very easy to tell simply look under the dash for a couple loose hanging electrical modules (not the really big ones that are factory) with a thousand wires coming from them and look like theyre not factory so look for solder butt conectors electrical tape etc
  3. #3 Re: Key fob
    Mar 2013
    ny
    The manual says the 97 does have keyless option. Is it true that the reciever is under the back lid
  4. #4 Re: Key fob
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    mines a 97 and I got keyless. try a new battery or maybe u need new key fob..got mine off Ebay
    Did u program correctly?
    Sent from my SGH-T679 using Tapatalk 2
  5. #5 Re: Key fob
    Mar 2013
    ny
    Ain't there codes on the trunk that say weither or not you have keyless I thought I read it on here
  6. #6 Re: Key fob
    Jul 2012
    California
    this is the correct way to program key fob. the last section 97-03 GP
    http://www.grandprixforums.net/how-p...fob-53653.html
  7. #7 Re: Key fob
    Aug 2012
    westlock alberta
    does the fob look new? there is always a possibility that the PO got a new fob but some how bought the wrong one. Another thing to try if possible separate the fob halves and see if theres any broken or burned circuitry. ive had to re-solder many gm factory fobs and almost all of the were atleast 10 years older than yours.
  8. #8 Re: Key fob
    Yoga city
    Au0 I believe is the code for keyless, you may look for the other rpo that is the alarm code.
  9. #9 Re: Key fob
    Mar 2013
    ny
    K Ty guys will look and yea the thing ain't fried I think it looks old
fob, key
