Thread: 1995 grand prix is possessed ..beyond exortism...electrical !
Results 1 to 8 of 8
  1. #1 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    rhode island
    Hi... Are there any fuses, fusible links, or circuit type breaker in the ignition switch apparatus. Runs fine, shuts off, has to be towed home.. sits a day runs fine. 90k. Thanks..
  2. #2 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    I don't believe so.. have you checked all the column to body connections? Have you checked that the ignition switch isn't bad?
  3. #3 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    rhode island
    Thanks for your reply. I will check the connections. I wish it would just quit it would make the trouble shooting so much easier.
  4. #4 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Aug 2012
    westlock alberta
    try swapping ignition relays in the block doubt the relay is the problem but thats all i can think of from the limited information you posted
  5. #5 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    rhode island
    thanks
  6. #6 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    rhode island
    I pulled the plug on the HID lights that were installed on the car before we got it...I had noticed that there was an excessive voltage drop when the lights were on..I also noticed there were some uncovered wires so I taped them...so far all is well.. thanks all
  7. #7 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    Orange County
    I have a 1999 GTP SuperCharge.... I had the same problem for a bout 3 months.....I was sent by my auto mechanic to see an auto electrician..I knew where it was but the crazy auto electrician wanted to do it his way and cost me 5 days of car rental and 5 days with him (5 hours of work)...trial and error on his part! I told him it was near or around the fuse box and told him the history...In the end - less than 1 hour of work to fix it! THE FIX: There was a loose, nearly broken wire leading to the fuse box under the hood (green wire). It powered the fuel pump. It would move around and my car would just shut off. Tow it - the car would start just fine after removing from the tow truck. If I put my hand down and pushed on the bundle of wires, my car would start, so I knew where the problem was. I had already changed the fuse that was slightly burnt. They fixed the wire and all is well.
  8. #8 Re: 1995 grand prix is possessed ..beyond exortism...electrical !
    Jun 2013
    rhode island
    thanks,,,
  1. 1995 Grand Prix
    By ChrisS in forum Introductions/Noob Questions
    Last Post: 04-14-2013, 05:10 PM
  2. 1995 Grand Prix GTP
    By Duzaman in forum Introductions/Noob Questions
    Last Post: 08-29-2011, 08:44 PM
  3. Possessed 97 Grand Prix
    By Candor723 in forum General Tech Discussion
    Last Post: 01-13-2011, 09:21 AM
  4. 1995 Grand Prix
    By AML in forum General Tech Discussion
    Last Post: 12-10-2009, 10:06 AM
  5. 1995 Grand Prix SE
    By VGPGT in forum Off Topic Discussion
    Last Post: 04-13-2009, 06:32 PM
