Thread: ZZP Poly Transmission mount
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 87
  1. #61 Re: ZZP Poly Transmission mount
    Arizona
    curious do you still have the factory engine mount in place or is that poly too. Im thinking your having issues because the motor sound is moving around more than the trans side.
  2. #62 Re: ZZP Poly Transmission mount
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    May be since it's been a while since i've had this mount in i've forgotten what it really feels like. Bc at idle my car is surprisingly smooth but when I drive it thats when it starts to vibrate and my RPMs have a slow reaction almost like a small hesitation through out the RPMs. Weird......
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  3. #63 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Poly motor mount may help even things out with the poly tranny mount but then it'll be 10x more vibration. Ok I exagerated but it will add more vibration. The motor mount is actually fine, its the tranny mount that allows most of the movement. I think the bolts are straight through the mount so that probably explains why those bolts are grounding out.
  4. #64 Re: ZZP Poly Transmission mount
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    What does ZZP have to say about any of this? Have they weighed in about the issue? Just currious cause Ive got the Intense upper motor mounts on there way and was thinking about doing the ZZP motor and trans mounts depending on how much vibration im having post upper mounts and vinnies spacers.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #65 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    I've been talking to Steve, Turbo Tim and the other guy and they all think I'm crazy. They said they've never experienced what im experiencing right now. I just don't remember it feeling like this and I could've swore that if anything I should feel a lil more vibration at idle in park and smooth out as I drive but mines does the total opposite. You have a link to the tranny spacers? Maybe they may help mask the vibration
  6. #66 Re: ZZP Poly Transmission mount
    If you have vibration from a mount..it'll be in gear, especially sitting still.
  7. #67 Re: ZZP Poly Transmission mount
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    So.... why not drain the fluid out of a stock mount, and inject poly inside? Think that'd be a better way of doing it?
  8. #68 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    I mean I know while in gear but isn't it suppose to smooth out as you drive? In gear sitting still is a giving but not while your driving at 60-70 mph. Maybe its just me
  9. #69 Re: ZZP Poly Transmission mount
    True.. 60-70 shoudl be pretty good.
    maybe by jacking it up..you bruised a CV
  10. #70 Re: ZZP Poly Transmission mount
    Marysville WA
    Quote Originally Posted by Dee23 View Post
    The spacers are for my drop I recently did, they are motor and trans mount spacers to bring the geometry back to stock now that im super super low (not). Im getting vibrations while at stop lights only so im pretty sure my issue is different then yours but just wanted to join the conversation. My thoughts is that I screwed up my upper motor mounts while flipping the dob bones so I have a set of Intense Polys comin. If that and the spacers dont fix it I was gonna try the ZZP Poly Trans and motor mounts as im way too lazy to drill and fill stock mounts until I absolutely have too.
  11. #71 Re: ZZP Poly Transmission mount
    Arizona
    You have a standard hydraulic lower motor mount? Might be time to level out the car with that poly lower instead. Vibration at park and idle sure but after that you shouldn't have issues. I'm in a different ball park though LS4's don't make vibrations at idle like 3800's do
  12. #72 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Funny thing is that Wbody store offers a stock looking tranny mount but claims it offers all the benefits of a polyurethane mount. It may be solid but I doubt it's equal to a polyurethane mount. Mind you the tranny mount I just took was a heavy duty mount from DEA from RockAuto. Yes its much beefier than a stock mount but the movement it still allowed was pretty evident
  13. #73 Re: ZZP Poly Transmission mount
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Why not just use this mount and get some dampening and have a SOLID trans mount for less than $25!!!
    This is what I'm running in my 00 GTP.
    Going on 4months now with no problems and a lifetime warranty if it ever does.
    http://m.advanceautoparts.com/mt/sho...rm=Trans+mount
  14. #74 Re: ZZP Poly Transmission mount
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Of god not that mount, it will split from the top and bottom and be more harmful then a broken stocker in less than 3000 miles, ask me how I know. plus it allows alot more movement than a stock one ever would.
  15. #75 Re: ZZP Poly Transmission mount
    Jul 2013
    Summertown Tn
    Lol, it does? Exactly how much power are you churning out of your Rocket!? I drive my car like I stole it from a police station and it has held up a LOT better than the stocker.
    The hydro mount would last me about a week before I destroyed it.
    Its the same mount ZZP sells but $40 cheaper.
  16. #76 Re: ZZP Poly Transmission mount
    Feb 2010
    Cleveland
    It's just a H-body mount. But yeah my car is right around 12.7's and destroyed that thing in no time not even driving it that hard, maybe 3 auto-x's and a few times at the strip.
  17. #77 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    If it ain't a self made poly mount or the zzp poly tranny mount than your gonna have plenty of movement unless your close to stock torque power which in that case the stock and or solid version may work fine for your application.
    Now I did go back and checked all my other mounts and noticed my torque strut mounts were too tight. I loosened them a bit and now I only feel a 1/4 of that vibration on acceleration. Word to the wise don't over tighten your mounts, yeah they say mounts can be tighten to infinity.....LOL, but there's a torque spec for everything believe it or not.
  18. #78 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Here's my tranny mount as of now, I loosened this a bit as well
    [IMG][/IMG]
  19. #79 Re: ZZP Poly Transmission mount
    Arizona
    That's gotta be some soft urethane there using to make there molds with mine is pretty damn tight
  20. #80 Re: ZZP Poly Transmission mount
    Who could of imagined a DIY poly mount is much stronger then the vendors poly mount •_•
    04 Comp G.
  1. WTB: One Poly motor mount.
    By Koniig in forum Wanted To Buy - Parts
    Last Post: 03-05-2012, 02:51 PM
  2. Poly Trans Mount
    By Boloknife in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2010, 06:59 PM
  3. Poly mount Questions????
    By basshead42 in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2009, 05:29 AM
