Thread: Delete. twin w2a ic plumbing
Results 1 to 11 of 11
  1. #1 Delete. twin w2a ic plumbing
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    Anyone have any suggestions on an effective plumbing of 2 w2a ic cores? Anyone with fluid dynamics experience, knowledge, advice would be greatly appreciated. The unfortunate thing is that the IC under the blower has 5/8 inlet/outlet, while the turbo IC has 3/4. Im a bit perplexed at the moment...
  2. #2 Re: twin w2a ic plumbing
    A simple adapter or stretching of the hose at two points wshuld fix your issue with sizing. Chose one of the two and stick with it throughout. On the duality.. two seperate front mounts or just one feeding both items?
  3. #3 Re: twin w2a ic plumbing
    Apr 2011
    Vassar, Mi
    For coming off the IC plate on the LIM, gates hose part # 20662. It's a 90* molded hose with 5/8" on one end and 3/4" on the other
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  4. #4 Re: twin w2a ic plumbing
    Jul 2011
    CT
    I didnt mean the size difference in regards to making it fit LOL, i meant in terms of orifice size and flow restriction.
    Both the supercharger ic and the w2a turbo ic will be cooled by one large 3.5in thick fmhe.
  5. #5 Re: twin w2a ic plumbing
    Jan 1970
    Maquoketa, Iowa
    If you can't change the 5/8ths, you can't change it, I would just try to run 3/4ths whenever possible. The biggest issue is if one intercooler/pump fails. Are you using one pump with that large fmhe? Air to air ic for the turbo and w2a under the s/c would be the most effective on the street and simplest in terms of reliability but may not be optimal for the track. Do you have temp sensors for post turbo, pre intake or how many are you going to run?
    When Matt had his twin turbo setup, he used 2 w2a cores fed by one large fmhe.
  6. #6 Re: twin w2a ic plumbing
    Jul 2011
    CT
    i have one large(biggest i could find) fmhe, which cools both a2w blower core and turbo core with one bosch pump
  7. #7 Re: twin w2a ic plumbing
    Oct 2012
    West Springfield
    It would be best to run the same DIA. hoses.
    The reason being, your 1 pump may end up pushing fluid through the path of least resistance. It may not flow evenly, or at all through one of the ICs.
    You may have to run 2 pumps to ensure flow.
    Just a guess and something to think about. I'm not entirely sure exactly how it would work.
  8. #8 Re: twin w2a ic plumbing
    GTX Level Member crbquist's Avatar
    Massachusetts
    Sounds complicated
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  9. #9 Re: twin w2a ic plumbing
    Jul 2011
    CT
    all done
  10. #10 Re: twin w2a ic plumbing
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Pics.
  11. #11 Re: twin w2a ic plumbing
    Jul 2011
    CT
  1. Twin charging
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 04-19-2011, 04:53 PM
  2. twin charging
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 12:43 AM
  3. Plumbing questions with old gas ligh
    By Rocket468 in forum Off Topic Discussion
    Last Post: 07-21-2010, 07:58 AM
  4. Hello from the Twin Cities!
    By mngp in forum Introductions/Noob Questions
    Last Post: 07-16-2010, 09:17 AM
  5. Twin Turbo?
    By Confusingboat in forum Turbo
    Last Post: 02-04-2010, 04:11 PM
