Thread: Swap questions
Results 1 to 11 of 11
  1. #1 Swap questions
    Dec 2010
    DMV
    Ok my engine is getting swapped this weekend and I have a few questions.
    First
    The 99 gtp engine is going into a 98 gt body.
    As I've read its a direct swap.
    What should I take from the gtp that the gt doesn't have?
    Also the gt body has gas in it. I'm guessing its regular gas. How can I remove the gas to ensure it doesn't get into the gtp engine?
    Thanks guys.
    Sent from my HTC One using Tapatalk 2
  2. #2 Re: Swap questions
    I'm guessing the GT doesn't come with HUD? If it doesn't I would swap that for sure. I
    04 Comp G.
  3. #3 Re: Swap questions
    Cleveland Heights, Ohio, United States
    Which HUD, the boost HUD? what about the wiring harness, is it direct or what, because I was about to type this in. I'm swapping my GT motor for a GTP motor and I know I need a PCM tune but what else? Is it any hard wiring thats needed?
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  4. #4 Re: Swap questions
    Being a regular member I wanna swat you for not searching...
    Keeping the GT trans or GTP?
    Gt - swap flex plates
    change over map connector, solder same colors to same colors
    remember to have teh speed relay circuit code removed from the tune.
  5. #5 Re: Swap questions
    Dec 2010
    DMV
    Lol your right but was looking and I didn't find to much. The entire engine and transmission is coming out of my gtp and going into the ground because it has a blown engine
  6. #6 Re: Swap questions
    Gonna bury it up to the charger?
    Ok engine and trans..
    Follow the how to pull both at once thread to pull both cars apart
    Drop it into the new car whole, put in the axles, hook up the wiring and swap the map connector.. pcm tune and off you go.
  7. #7 Re: Swap questions
    Dec 2010
    DMV
    Ok great, what should I do about the gas left in the tank?
  8. #8 Re: Swap questions
    Two choices..
    Rig up a relay to stay on and pump it out with the pump via the fuel line
    Or.. pull the pump and pump it out by hand.
    Or.. option C..cause there's always an option C
    Leave it.. add torco or tolulene/xylene and boost up the octane
  9. #9 Re: Swap questions
    Dec 2010
    DMV
    If it was you bill what would you do?
  10. #10 Re: Swap questions
    I'm lazy.. you know you are gonna let it idle forever and then probably go straight to a gas station .. along with being super nice
    I'd do option D.. be nice and just use it up while mixing in some 93 for good measure.
    BTW, for more room to clear the trans past the master cylinder. Unbolt the two 15mm's that hold the master to the booster and lay it over next to the strut. The hoses will reach.
  11. #11 Re: Swap questions
    Dec 2010
    DMV
    Awesome man. Awesome
  1. Pre Top Swap Questions
    By Points70 in forum General Tech Discussion
    Last Post: 04-08-2012, 11:11 PM
  2. Gen V Swap Questions
    By jdbaringer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:44 PM
  3. Got some questions about the top swap??
    By biggmman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 06:24 PM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
