Thread: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    May 2013
    renton
    I disconnected the battery for well over an hour. Still having the same problem.
    Any other ideas?
  2. #22 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    London Ont, Canada
    i didnt read.. have you cleaned the maf?
    the IAT built into the maf will cause that kinda problem, so will a sever vacuum leak
  3. #23 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    may sound super dumb but ive had the same thing happen all because i didnt plug a few things back in so mack sure EVERYTHING is plugged back in mine was not plugging in the maf and evap system that created my problems
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #24 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    May 2013
    renton
    So here's an update on my situation.
    I replaced the gas pedal with the accelerator pedal position sensor and reset the computer, then got the same code after driving for a few minutes. I sent the part back and got a new one from the factory repeating the process and got the same results. Next I cleaned out and then replaced the mass airflow sensor and still no luck. The same issues with the same codes. Any other ideas?
  5. #25 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    Slower, Lower Delaware
    I'm with Mad Monkey. I had a similar fate when a vacuum line was off.
  6. #26 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    I had the same issue, and swapped out the pedal and all was good. it was like $60 at autozone.
  7. #27 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    You need to do a app learn when you install a new pedal assembly.
    (in theory)
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #28 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    May 2013
    renton
    is that a process performed with a scanner?
    I have now replaced the mass airflow sensor and still no luck. I did however just noticed that my serpentine belt is heavily worn and in need of replacement. If one or more Pully has slipped and my timing is off could that be causing this problem?
  9. #29 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    May 2013
    renton
    And at no point has any vacuum hose been removed, just the main intake tube with the maf assembly
  10. #30 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    Your belt has absolutely nothing to do with your timing.
  11. #31 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    Arizona
    Quote Originally Posted by chadwick View Post
    No. You need to go through and test the connections between your PCM and app and tb
  12. #32 Re: 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    Jan 2013
    Edmonton, Alberta
    yes, you will need a bi-directional scanner. Make sure the peddle is in its 0% throttle postion. When you start the relearn, the sensor output is recorded and used as your new baseline for throttle postion
    if that doesnt help u might want to check for wiring problems between the app and tb
  1. 1998 Pontiac grand prix,3800 Series 2 "Power Steering Problems"
    By Gchronic in forum Introductions/Noob Questions
    Last Post: 12-04-2012, 08:02 PM
  2. Clearing "Service Engine soon" light
    By bvdogg in forum General Tech Discussion
    Last Post: 09-01-2012, 01:14 PM
  3. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
  4. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
