Thread: Changing out intake manifold gaskets
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Changing out intake manifold gaskets
    dealer, ouch. not for me.
    i went to advance auto, they were the only store that had small T's. every one else had this huge ass T that dont really fit or work. and it was one for 3 bucks.
    got a 2 pac of T's, you need 2. and 3 feet of vac line for under 5 bucks.
    and the fat vac hose off the TB is more then likely to break too. the $5 i spent covered 4 inches of the fat line, then i took the smaller line shoved it onto the fat line, then to the stock plastic line.
  2. #22 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Where did you go to get the vacuum line and the only reason im was going to the dealer was because I was told that everyone else sold crappy coolant elbows.
  3. #23 Re: Changing out intake manifold gaskets
    any auto parts store will have the vac line, i got the small T's at advance auto.
    if you want they sell the metal elbows now, or get the dealer elbows. but the T's id get at the part store, why pay the dealers high prices. they flat out over charge for everything, thats why we all hate the dealerships.
  4. #24 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    If they have metal elbows I will just pick them up but trust I don't like the dealership anymore than the next guy
  5. #25 Re: Changing out intake manifold gaskets
    Quincy, Mass
    Yes they make metal ones. Here's the thing with the metal ones, it's all aluminum and they corrode fast and get stuck. They still can break off. The real issue with the elbows is that the orings go flat, so just rtv around the orings and you'll be all set.
    I watch bill boost break off a metal elbow last week because it was stuck in the water pump. The 97-98 water pump had a metal elbow that was attached to it, gm changed to the plastic ones because that elbow would corrode and break inside.
    No more GP 04 Impala SS Indy:
  6. #26 Re: Changing out intake manifold gaskets
    the metal one are not sold at the dealerships, just so you know that. its a dorman part. theres a thread here with the part #.
  7. #27 Re: Changing out intake manifold gaskets
    Quote Originally Posted by Swiggles View Post
    wasn't that elbow also rtv'ed in? that bill snapped?
  8. #28 Re: Changing out intake manifold gaskets
    Nov 2011
    NY
    For the $6 for the elbows... Just change em out once a year, no leak, no breaking, done!
    Geeeeze!
  9. #29 Re: Changing out intake manifold gaskets
    Quincy, Mass
    You shouldn't have to change them once a year. There should be no need to change them ever if they are install right. A bead of rtv around the orings and you'll be good for years to come.
  10. #30 Re: Changing out intake manifold gaskets
    Quincy, Mass
    It might have been but that's not why it was stuck. I always rtv the rings, metal and plastic, the plastic won't corrode so you can still get the piece out if it breaks.
    With all that being said, I have the metals ones on my car buts that's because they are shiny
  11. #31 Re: Changing out intake manifold gaskets
    i did mine, first time cleaned the holes well, oiled the rings, slid them in, no leaks, then i had to change the upper one with the lim job, same deal, just oiled, no leaks. knock on wood. mine are the dorman plastic.
  12. #32 Re: Changing out intake manifold gaskets
    Quincy, Mass
    And you shouldn't need to use rtv, I do it as a precaution. Sometimes they go in on an angle that you can't see and can cause leakage
  13. #33 Re: Changing out intake manifold gaskets
    At an angle you can't see? The thing is right out there in the open.
  14. #34 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    What should I use to clean the intake manifold? Just Brake cleaner or can I just let it soak in something?
  15. #35 Re: Changing out intake manifold gaskets
    Grease and grime..I use purple power/simple green, then to scrub... any loved ones toothbrush works well. To clean the elbow holes..I use a finger and some steel wool....helps if you are wearing white gloves and pretending you're a doctor.
  16. #36 Re: Changing out intake manifold gaskets
    i used a scotch bright pad, and brake cleaner, on the heads side, and the intake side ports, and both the sc and top of the lim.
    i had to use 100 grit sand paper to get the burnt on gasket by the lims 2 coolant holes, it was baked on there real good.
  1. How to tell if you have the GOOD Lower Intake Manifold gaskets.
    By bps02gtp in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2012, 07:38 AM
  2. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  3. Changing intake gaskets and a bolt is stripped
    By darkcherrymetallic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2011, 01:10 AM
  4. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  5. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
