Greetings
2004 GT2 just rolled over 230,000 miles. Here is a rundown of everything wrong with it:
-Two front wheel hubs with some play
-Oil leak, one quart every 2000 miles
-Steering rack leak
-Horrible rattling under the car when hitting potholes, not the exhaust
-Needs shocks and struts
-Transmission has begun to hesitate in the 1-2 shift
-AC causes a weird surge, then almost stall
-Fuel pump losing prime, no puddles on the ground
-Motor ticks on startup when its colder than 20F
Should I bother putting more money into this car? This is what I have done in the last year
-Front sway bar
-Water Pump
-PS Pump
-Battery
-Intake Plenum
-Elbows, and switched to Prestone Green
-Front pads, rotors
-Rear pads
Thanks
