Thread: 97-03 Need pics of dash off? Post before I get it back together
Results 1 to 9 of 9
  1. #1 97-03 Need pics of dash off? Post before I get it back together
    Some know the neighbor kids car smoked the DRL diode wiring.
    Using the FSM's I'm not finding the splice where they say it should be. Having to go a bit deeper to fix a short somewhere in the dash.
    You might ask..where's that last pic?
    Anyone need any pics of stuff before it goes back together?
  2. #2 Re: 97-03 Need pics of dash off? Post before I get it back together
    Nov 2011
    NY
    Holy cow!!!
    Painful!!!
  3. #3 Re: 97-03 Need pics of dash off? Post before I get it back together
    Mar 2013
    Jersey
    wow!!
  4. #4 Re: 97-03 Need pics of dash off? Post before I get it back together
    Chilliwack BC
    wire nest...i've only pulled one dash in my life...i swore i'd never do it again
  5. #5 Re: 97-03 Need pics of dash off? Post before I get it back together
    GT Level Member Tea Time's Avatar
    New Brunswick
    since you're in that far, in your professional opinion bill.... how difficult would it be to take all the wiring out and swap it over to a different year. i have a 97 shell but i wanna run a 99 harness / ecm in it. the donor car is rotted out in the rear.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  6. #6 Re: 97-03 Need pics of dash off? Post before I get it back together
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    WOW Thanks I need to replace the dash in one of mine not looking forward to taking it off and then going to pul-a-part and doing it again What did you do about the passenger air bag or do I not have to disconnect to remove the dash?
  7. #7 Re: 97-03 Need pics of dash off? Post before I get it back together
    Quote Originally Posted by Tea Time View Post
    I wouldn't replace the interior harness in your car. Run the 99 under the hood. I did in my 97 Bonneville. The way I did it was to map the pinouts where the engine harness connected to the body. In the case of a GP, that is at the relay center IIRC. Map your 99 and a 97 both. Compare and move the few wires that are different. Use the circuit numbers for hints if things seem different, GM typically uses the same labeling on circuits.
    Quote Originally Posted by jmak gtx2 View Post
    Passenger bag is attached to the structure of the dash, not the pad. I didn't have to unhook either bag. If you do unhook a bag though..put your body down by the floor when unhooking. That way you can't get clipped and beaten by a bag. Pulling the dashpad off isn't bad at all.
    Basically it was:
    Pull lower panel under steering wheel, lower wheel (a few 7mm's and some 13mm's, no wire disconnection)
    Pull glove box (7mm)
    Pull radio, unbolt hvac (you can leave it hooked up), pull cluster, fog switch, headlight switch (plug back in to stop dinging)
    Pull console (10mm electrical disconnect)
    Pull ashtray (7mm and electrical)
    Pop the switches to left of glove box for trunk etc
    unbolt OBD2 connector (7mm)
    Pull dash trim (turn light and sensor counter clock to disengage)
    Unhook module at top passenger (under trim you just took off)
    Pop the two a pillars
    Remove 4 10mm from trim panel area
    Remove a few more 7mm holding pad down lower
    Put shifter in "1" and slide over off.
  8. #8 Re: 97-03 Need pics of dash off? Post before I get it back together
    New Brunswick
    thanks bill, i was gonna run the whole 99 harness because i wanna put the digital heater in the 97 and it currently only has the 3 dials. not only that, i wanna run the 99 gtp dic as my 97 crapped out. maybe this isn't worth the headache?
    '97 GTP - Project
  9. #9 Re: 97-03 Need pics of dash off? Post before I get it back together
    Apr 2012
    Goderich, Ontario
    I got a quick question for you. The last few days my heater has been blowing only slightly warm/cool air (heater core?) and now today the fan speeds don't work at all. Also when I turn the fan on the headlights shut off.
    -Paul Walker
  1. No dash back lights
    By gpse2000 in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2013, 08:32 PM
  2. LED light strips under dash and under front seats facing the back
    By DirtDog in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2012, 04:02 PM
  3. pics of humount dash insert
    By z3r0 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2012, 03:39 AM
  4. Back in the GP Game - Cambridge ON with pics
    By Elite6 in forum Introductions/Noob Questions
    Last Post: 10-11-2011, 08:24 PM
  5. My 02' Transformation - back from bodyshop, new pics.
    By BlownBigBlock in forum Members Rides
    Last Post: 09-10-2011, 10:39 PM
