Thread: Got check engine light :/
Results 1 to 20 of 22
  1. #1 Got check engine light :/
    Aug 2012
    Tukwila, Washington, United States
    Can i drive home?
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Got check engine light :/
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Yea. Odds are you will need a new MAF sensor or just clean yours. All that will happen is it may run a little rough at times but youll make it.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Re: Got check engine light :/
    Aug 2012
    I just got mine on ebay.
    But i had only one code. Now i have the other one :/
  4. #4 Re: Got check engine light :/
    Yea the Ebay ones are junk. I had that issue back in Nov and got an ebay one. It helped for about 2 weeks or so before it started making the car miss and die at idle. I just got another one from Morad auto for like $45 that was used and it cleared up all my problems.
  5. #5 Re: Got check engine light :/
    Orrrrr you could get a new OEM replacement for like $150
  6. #6 Re: Got check engine light :/
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    You've seemed to have a hodgepodge of problems since you joined...
  7. #7 Re: Got check engine light :/
    Aug 2012
    ^ my car gives me no rest.
    I spend so much time and money on this stupid car.
    And the code is not the maf.
    The maf is just a stored one
    Its the other one
  8. #8 Re: Got check engine light :/
    Nov 2011
    Indiana
    i've never seen such persistent problems, even mine aren't this bad lol. Ditch the thing
  9. #9 Re: Got check engine light :/
    Delete the codes and see if they come back
  10. #10 Re: Got check engine light :/
    Aug 2012
    Ok so thats what i did.
    I unplugged the maf sensor.
    Then i got only the maf code.
    Plugged it back. Code still on
    Then i deleted all codes.
    Now i have no ses light but start up feels the same like when disconnected.
    When u turn on the car the rpm goes up to 1700 then to 500 and stays on 850.
    ** after few tries it gets better start ups.
    I didnt try to drive it yet after reseting.
    I notice less power when i drove it back.
    Took me more time to get to 60 mph than usual.
  11. #11 Re: Got check engine light :/
    You might have a vac leak somewhere then. That most likely would throw the lean code.
  12. #12 Re: Got check engine light :/
    Likely you have a maf or maf connector issue.
    Please google or at least search these codes and you'll learn all about them, what causes them and why they are often appearing together. You'll also learn how one can be set in one drive cycle and the other takes two to set it. Which explains one current, one pending.
    To drive.. unhook maf, drive nicely.. enjoy the orange glow of the SES.
  13. #13 Re: Got check engine light :/
    Aug 2012
    I searched some of ur name with the code.
    I can check for vac leak. I dont think its a leak tho. I think its something with my CAI caused the maf to go bad.
  14. #14 Re: Got check engine light :/
    Well..if it's over oiled a cone filter can hurt a maf. Because of the oil hitting the maf.
    You don't need to look for a vacuum leak. You have a bad maf.
  15. #15 Re: Got check engine light :/
    Aug 2012
    Light is gone. But i dont trust my generic maf.
  16. #16 Re: Got check engine light :/
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Quote Originally Posted by raverockstar View Post
    Contact Morad Parts. Ask for a price of a replacement MAF. Order it. Receive it a few days later. Install. Be happy.
    Never been disappointed with a Morad supplied replacement part yet.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  17. #17 Re: Got check engine light :/
    Aug 2012
    P0171 came back
    Some monitors are "incomplete" what does it mean?
  18. #18 Re: Got check engine light :/
    Feb 2008
    Cumming GA
    Incomplete means you haven't run the car enough to get a valid reading. Happens when you disconnect the battery and everything is reset. I found this out when I disconnected the battery to clear a code, then took the car in for an emissions test. I was told the same thing. You'll have to drive the car for about a week or 100-200 miles, then those incompletes will be complete.
  19. #19 Re: Got check engine light :/
    Aug 2012
    I figure this thing. Tnx anyway.
  20. #20 Re: Got check engine light :/
    Aug 2012
    I got an other used maf sensor from morad this time ( the forth one already)
    When i turn off the car and start again
    The car rpm goes up and down again.
    Dont know what to do anymore.
    I cleaned it and everything as well.
    http://www.youtube.com/watch?v=zqpuKRK2llo
  1. check engine light...
    By Alsafi92 in forum General Grand Prix Discussion
    Last Post: 02-19-2013, 01:13 AM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. check engine light goes on and off!!
    By stanggreg90 in forum General Tech Discussion
    Last Post: 06-19-2009, 12:37 AM
  5. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
