Thread: 04 grand prix stalls above 1800rpm
Results 1 to 20 of 21
  1. #1 04 grand prix stalls above 1800rpm
    Mar 2013
    michigan
    Hello. Im new to this forum and I'm hopping I can get some advice. Last week my car stalled on me when I was backing out of the driveway. It seems to stall when ever the RPM's get above 1800. I will idle all day until the gas runs out. I Changed the fuel filter since I have 256,000 miles on the car. I've cleaned the MAF sensor. still didn't work so I took it to a shop after they said that it was the fuel pump. So I changed that out and still does the same thing. There is no miss, studdering of any kind. It just stall when you push on the gas.
  2. #2 Re: 04 grand prix stalls above 1800rpm
    Hmmm
    Not the average problem here.
    Supercharged or not?
    Any work done recently before the issue occurred?
    Have you checked for a vacuum leak say at the hose to the brake booster? That elbow into the booster is a check valve and they can go bad.
  3. #3 Re: 04 grand prix stalls above 1800rpm
    Mar 2013
    michigan
    non-supercharged. No recent work done. No I haven't checked for vacuum leaks. I was told that the catalytic converter might be plugged up.
  4. #4 Re: 04 grand prix stalls above 1800rpm
    It could be.. easy way to test is to remove the front O2 sensor. Wear hearing protection and don't beat it, but try and see if it stalls.
  5. #5 Re: 04 grand prix stalls above 1800rpm
    Mar 2013
    michigan
    if you very slowly accealerate you can drive it anywhere but as soon as you give it to much gas it stalls.
  6. #6 Re: 04 grand prix stalls above 1800rpm
    Jan 2013
    Brandon, Mississippi, United States
    I had this same problem on my old car it turned out to be the cam shaft position/precision sensor
  7. #7 Re: 04 grand prix stalls above 1800rpm
    Mar 2013
    michigan
    @justinhvr1. thanks haven't thought of that. I'll have to test it.
  8. #8 Re: 04 grand prix stalls above 1800rpm
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I have seen this problem before
    One was a clogged cat.
    The other was a broken purple/white wire on the Crankshaft Position harness.
    A third possibility would be a bad crank sensor
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  9. #9 Re: 04 grand prix stalls above 1800rpm
    Slower, Lower Delaware
    I got the stability error everytime I stepped on it at all hard. Replaced both front hubs, PCM. it turned out to be a vac line that fell off.
  10. #10 Re: 04 grand prix stalls above 1800rpm
    Mar 2013
    michigan
    sorry working alot. But pulled O2 sensor before cat. car still stalls. All Vac. lines seem ok. What about the Throttle Position Sensor? auto Zone says I have to buy the whole throttle body.
  11. #11 Re: 04 grand prix stalls above 1800rpm
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    I get a similar stalling issue above 3000rpms when trying to accelerate. I'll check th vacuum line from the brake booster, but where are the other vacuum lines? I figured I should check them all out to be sure they are fine but I'm not sure where to look. Thanks for the help.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  12. #12 Re: 04 grand prix stalls above 1800rpm
    Nov 2009
    I found most of the vacuum lines, replaced two of them and did seafoam (in gas & vacuum line). Still have the same issue but atleast I know the vaccum lines are better and the engine is a bit cleaner. Couldn't find any leaks in any exhaust parts when the smoke from seafoaming the vacuum line was coming out the back.
  13. #13 Re: 04 grand prix stalls above 1800rpm
    Did you pull the tb and clean it up?
  14. #14 Re: 04 grand prix stalls above 1800rpm
    Nov 2009
    I didn't unbolt it but I cleaned the outside and as far back as I could reach by hand with a rag and TB cleaner about a week ago. Also, cleaned MAF Sensor & Air Filter on the CAI
  15. #15 Re: 04 grand prix stalls above 1800rpm
    Pull it off and make it spotless
  16. #16 Re: 04 grand prix stalls above 1800rpm
    Nov 2009
    If I do, do I need to use anti-seize or anything else on the bolts or the mating surface?
  17. #17 Re: 04 grand prix stalls above 1800rpm
    No Don't have to replace the gasket either
  18. #18 Re: 04 grand prix stalls above 1800rpm
    Nov 2009
    Anything specific to clean the gasket with before putting it back on or just rub off any dirt/debris on it? I'm going to have a new one with me just incase the gasket falls apart. Gonna do the TB once my gift card from Advance Auto comes in.
  19. #19 Re: 04 grand prix stalls above 1800rpm
    Just wipe the gasket off and reinstall.
  20. #20 Re: 04 grand prix stalls above 1800rpm
    Nov 2009
    Since my last post I took off TB, cleaned it, replaced the TB Gasket, cleaned the MAF Sensor. These didn't fix the misfire problem. I finally had a chance today to replace both spark plug wires I had gotten for free from MSD. They were the cylinder 4 & 6 wires, replaced them, took off all other wires and used dieletric grease on the coil & spark plug end of the wires. This fixed the misfiring issue. I'm very excited.
  1. Grand Prix stalls while driving
    By PokerBlakeB in forum General Tech Discussion
    Last Post: 03-02-2013, 09:47 PM
  2. 02 grand prix stalls after starting
    By jward2155 in forum General Tech Discussion
    Last Post: 08-10-2012, 06:51 AM
  3. 97 grand prix stalls
    By Leah and Justin in forum General Grand Prix Discussion
    Last Post: 07-30-2012, 01:58 PM
  4. grand prix gt randomly stalls
    By Arzona Miller in forum General Grand Prix Discussion
    Last Post: 06-29-2012, 05:33 PM
  5. '01 Grand Prix GTP won't start and stalls
    By tmac10 in forum General Tech Discussion
    Last Post: 12-02-2010, 10:26 AM
