Thread: Correct valve stem size?
Results 1 to 3 of 3
  1. #1 Correct valve stem size?
    Dec 2012
    Where 4T65E's were born
    Since I'll be cleaning up my bead surface on my rim to hopefully solve a tire leak, I'd like to replace the valve stems as well. A quick search on Advance's pages reveals many different sizes. I can't just remove them, and go to the parts store to compare cause you know, I need them to drive on. Anybody know which size is appropriate for my stock GP aluminum rims?
    These are the search results:
    Any help or advice on how to find out is appreciated.
    Sold.
  2. #2 Re: Correct valve stem size?
    Feb 2008
    Measure the length of your existing one, and get the same length. There are typically two diameters. Most automotive wheels use the smaller (.435" iirc).
    Sent from my SkyRocket
  3. #3 Re: Correct valve stem size?
    The ones we use at work are just over an inch long for cars.
  1. Correct valve stem seals?
    By 88formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2012, 02:48 PM
  2. Changing valve stem seals - what else can i do?
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 09:52 PM
  3. How to remove the valve stem on TPMS valves?
    By mkb in forum Tires & Wheels
    Last Post: 05-27-2010, 01:16 AM
  4. Valve stem caps??
    By hester21289 in forum Tires & Wheels
    Last Post: 03-02-2008, 06:20 PM
  5. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
