Thread: 2001 Grand Prix Double din questions!
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: 2001 Grand Prix Double din questions!
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    Sound stream radios are not worth it, dont buy them. You get what you pay for in this case. When i comes to buying speakers, just look at what materials they are made of for quality. They are all basically made the same and will sound great and last awhile if powered right.
  2. #22 Re: 2001 Grand Prix Double din questions!
    Quote Originally Posted by Jcinstalls View Post
    Aaaaannndddd bam! My first thread picture
    congrats on your new car btw! My first GP was my mothers too.
    if it didn't just snow were i live i would take my dash off. Well first you are going to need aftermarket radio harness 20$ and an GM antenna adaptor 20$. Also to make this look good you might consider a sheet of plastic to cut and fill in gaps around the radio or any other way you want, and paint? Cool now take off the dash. The plastic is brittle on our old cars so take it easy, your going to need those clips too. Unplug everything and remove the radio. Unbox the new radio and see how it sits. Now obviously you can see that the heater controls are in the way, its easy to unscrew grind off the plastic pins, drill new holes and install the new screws in a lower spot on the plastic it originally screwed into. Be careful here because it can be to low and the knobs will hit the dash cover (measure twice drill once) you want it as close as you can get so the knobs wont hit.
    Is that carpet on your dash?
  3. #23 Re: 2001 Grand Prix Double din questions!
    Feb 2013
    Missoula, MT
    Yep its there to cover up sun damage on the air bag pop out. Its black and wavy, It also matches the door panel inserts. Aftermarket headliner and carpet too.
  4. #24 Re: 2001 Grand Prix Double din questions!
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Ragen and Killerspeed101, what year is are your vehicles, do they have the Bose system, and what wiring harnesses did you use?
  5. #25 Re: 2001 Grand Prix Double din questions!
    Cleveland Heights, Ohio, United States
    What installation kit is that and did you have to use any special brackets or mod the install kit?
    Quote Originally Posted by RAGEN View Post
    It's possible to get one in without having to move the climate controls. Only thing I trimmed was the back of the radio were the factory stub was.
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  6. #26 Re: 2001 Grand Prix Double din questions!
    SE Level Member RAGEN's Avatar
    Feb 2013
    SE
    That's no installation. I made a couple of brackets and bolted it up. Measure over and over.
  7. #27 Re: 2001 Grand Prix Double din questions!
    Feb 2013
    Saskatoon, SK Canada
    I got my GTP from my grandma. I wanna double din but dont wanna mess up anything
  8. #28 Re: 2001 Grand Prix Double din questions!
    what did you even use to make the brackets, im new to it
  9. #29 Re: 2001 Grand Prix Double din questions!
    Aug 2012
    Tukwila, Washington, United States
    Quote Originally Posted by troy33busch View Post
    Hey guys, my names Troy I’m 19 years old and I’m brand new to this site.... My mom just got a new car so that means i get her 2001 Grand Prix... I’m very excited because that puppy has 51,000 miles on it!!! Considering she works from home. With that said i have always been a guy who likes to replace air intakes in his friends cars or put new speakers/ subs... Looking back maybe i should have done a little more homework... I plan on doing a few things to my moms car off the bat. One of them is putting in a new stereo. Last night i went over to best buy just to look around at some head units, amps and dash kits for the car. I came across
    JVC KW-AV60BT DVD receiver at Crutchfield.com
    I talked with a rep named josh and as a matter of fact it was his last night there because he said he got a new job. He said that the dash kit for it is in the back but that this head unit will definitely fit.... little did i know after googling today that its not that easy.... So if anyone knows anything regarding my issue please tell me!!!! Oh and the main reason why I bought that head unit was he sold it to me for 179!!!!
    you don't need to cut anything for this stereo.
    i have a pioneer double din same size as urs. you dvd is smaller than regular double din.
    it will fit perfectly
    and for the sides
    you need 2 plastic sheets (homedepot) and make a hole with a solder iron for the screws
    Grand Prix gt 1999 v6 3.8L coupe.
  10. #30 Re: 2001 Grand Prix Double din questions!
    Feb 2013
    SE
    Quote Originally Posted by LowRidinCrew View Post
    Used some angle iron from Home Depot.
  1. 2001 Grand Prix GT Wheel Questions
    By pessacake in forum Tires & Wheels
    Last Post: 01-02-2013, 09:59 PM
  2. 2001 GTP steering wheel controls and fac amp install double din?
    By blazed16 in forum Audio, Security & Visual Electronics
    Last Post: 03-15-2012, 07:49 PM
  3. 2001 Grand Prix A/C contol replacement questions
    By wandre120 in forum General Tech Discussion
    Last Post: 08-21-2011, 09:40 AM
  4. Is there any Double DIN for grand prix 1998
    By TheCoookie in forum Audio, Security & Visual Electronics
    Last Post: 05-22-2010, 09:28 AM
  5. Fitting a double din reciever into 00 grand prix
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 01-26-2008, 11:57 AM
