Thread: final drive gear swap
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
  1. #1 final drive gear swap
    Mar 2013
    Kansas
    I have a 99 Pontiac Grand Prix GT n/a that is starting to have slight transmission issues. I talked to my local transmission mechanic (who is the only transmission mechanic I will have work on my car) about the issues and a possible rebuild but with a change in the final drive ratio from the 3.29 to the 3.05. He wasn't sure if it was possible and what, if any, computer issues that might cause. I guess what I am wondering is if it can be done and what all it involves. Anyone with any idea?
  2. #2 Re: final drive gear swap
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Final drive? You mean changing your differential and you only have 3.29 gears if you have a comp G or GXP
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: final drive gear swap
    St. Louis
    I thought the 97-03 GP GT's had 3.29 gears, while the GTP has 2.93?
    If you change the gear ratio you would have to tune for it I would think or it would confuse the PCM and cause strange shift points and whatnot.
  4. #4 Re: final drive gear swap
    Oct 2011
    Michigan
    You'd definitely need a tune but no only the comp G and GXP came with 3.29 gears all other cars came with 2.93 and trim level (SE, GT, GTP)
  5. #5 Re: final drive gear swap
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    you sure about that fella? lol
  6. #6 Re: final drive gear swap
    Se and gt had 3.29
  7. #7 Re: final drive gear swap
    And you have to tune for the swap
  8. #8 Re: final drive gear swap
    Jan 2012
    Canada
    Yup you would need a tune.
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  9. #9 Re: final drive gear swap
    Oct 2011
    Michigan
    A 99 Grand Prix SE (with a 3.1) had 2.93 gears I know this for a fact
  10. #10 Re: final drive gear swap
    Then someone swapped the trans because from the factory they had 3.29's. My grandma had one.
  11. #11 Re: final drive gear swap
    SE Level Member EricGTP's Avatar
    Apr 2009
    Kansas City
    GM 4T60-E transmission - Wikipedia, the free encyclopedia
    Although I don't see why you would want to go to a lower gear other then fuel mileage you can do it. But it would require a tune.
  12. #12 Re: final drive gear swap
    The link is to 4T60, 98+ all had a 4T65. Gear ratio's were close, not exact.
    asite: I dunno what goofy thing or factory ordered car your Grammy had, 2.93 was only used in SC cars, on any GM 3800 platform from 97 up.
    GT would be 3.29
    Regal could be found as a 3.05
    Bonneville, Park Ave, Riviera, LeSabre etc could be found as 3.05 in an NA version. Most of them could also be found as a 2.86 (or was is 2.85).
    I've seen swaps where it didn't confuse the pcm. If you found issues/TCC lockup acting funny then you could reprogram. Or reprogram from the start. IMO you need to reprogram because your shifts will happen too soon based on the 3.29 points. So the 3.05 is likely to be boggy.
  13. #13 Re: final drive gear swap
    Apr 2009
    Kansas City
    You have to click on the 4t65e once you get into the link. 4t60 isn't a whole lot different then the 4t65 which is why they are combined into one page.
  14. #14 Re: final drive gear swap
    Can't click from current location. Thanks for the info though, I didn't realize it was in there as well.
  15. #15 Re: final drive gear swap
    Apr 2009
    Kansas City
    No problem. Only thing about that page is its showing the gxp with the 2.93 and everyone else is saying it is a 3.29. The comp g is listed with the 3.29 though.
  16. #16 Re: final drive gear swap
    I thnk the GXP had taller gears. Hang on..lets get confirmation
  17. #17 Re: final drive gear swap
    Yoga city
    yup its truth, i was reading an article over on ls1 tech about the monte getting 3.29 and gxp getting 2.93.
  18. #18 Re: final drive gear swap
    Apr 2009
    Kansas City
    I would love to know why they chose to put a 2.93 in these cars. Maybe a reliability thing.
  19. #19 Re: final drive gear swap
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Better top end better gas mileage slower acceleration
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  20. #20 Re: final drive gear swap
    Apr 2009
    Kansas City
    Only true reason would be better fuel mileage. From the factory they had a limiter on top speed.
  1. How to install final drive?
    By chapmanrandall in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2011, 07:14 AM
  2. Final Drive Misinformation?
    By Confusingboat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-24-2011, 10:30 PM
  3. What will my final drive ratio be?
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 01:09 AM
  4. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
