Thread: 2 Small Problems. Any ideas?
Results 1 to 8 of 8
  1. #1 2 Small Problems. Any ideas?
    SE Level Member BigKev2403's Avatar
    Feb 2013
    Cleveland Ohio
    Okay I found two more problems with this car that I just bought. For those who haven't seen my first thread it is a 2001 GTP.
    1. The heater control only works on high. I bought a new control panel and that did not fix it.
    2. The washer fluid isn't working. I pull the lever and the wipers go but no fluid.
    Boooooo!
  2. #2 Re: 2 Small Problems. Any ideas?
    Ocala, FL
    1. Blower motor resistor
  3. #3 Re: 2 Small Problems. Any ideas?
    Grand Rapids, MI
    2. pump inside the reservoir most likely.
  4. #4 Re: 2 Small Problems. Any ideas?
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    +1 On blower motor resistor
    and have you checked to make sure all the lines for the washer fluid are connected?
  5. #5 Re: 2 Small Problems. Any ideas?
    Check fuses or its the pump for the washer fluid.
    And as said above, the Blower Motor Resistor needs to be replaced.
  6. #6 Re: 2 Small Problems. Any ideas?
    Feb 2013
    Cleveland Ohio
    Awesome, thank you for the quick replies...I'm headed to Advance Auto today to get the part for the heater control...that is such an annoying problem
  7. #7 Re: 2 Small Problems. Any ideas?
    Yoga city
    1. blower motor resistor< classic problem
    2. either unplug, bad pump, actually line that leads to arms isnt conected, or multi switch is bad
  8. #8 Re: 2 Small Problems. Any ideas?
    On the washer pump. You aren't my neighbor kid who refuses to read her owners manual. On your year, the pump is operated by PUSHING the part of the turn signal stalk that has a picture of a window being sprayed. Might also say wash.
    Meaning..it's not the one that says mist. Mist means, clear a light mist off the window with the wipers only. No fluid.
  1. Woofer Position Question(update-new problems/ideas)
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2012, 09:14 PM
  2. 03 grand prix gt - 2 small problems
    By smil27 in forum General Grand Prix Discussion
    Last Post: 04-15-2012, 09:40 PM
  3. Small Coolant Leak - Any Ideas?
    By Hippo Machine in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2011, 08:54 AM
  4. small pic edit
    By iroc2 in forum Off Topic Discussion
    Last Post: 11-21-2010, 03:58 PM
  5. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
