Thread: Stepdad
Results 1 to 14 of 14
  1. #1 Stepdad
    Feb 2013
    Minnesota
    My stepsons 02 grand prix has oil in the coolant. What caused it and how to fix it. I have heard that the car has a plastic intake manifold and that could be the problem. What is the answer?
  2. #2 Re: Stepdad
    Well you can't get oil into the coolant, unless the block cracked. We don't have a oil cooler.
    You have trans fluid in the coolant from the side tank or its dexcool coolant sludge that looks like a oil.
    And if the intake gasket were never done, it might be a good idea for a change and a coolant flush.
    Also, where at in MN are you?
  3. #3 Re: Stepdad
    I don't agree with Ox's info. Can't see how an upper intake that has no oil in it could contaminate it. Upper gaskets have no oil, coolant elbows have nothing to do with oil. Even lower manifold gaskets have no oil.
    What color does the oil appear to be?
    Has the cooling system been maintained properly?
    If the oil is reddish in color, you have a trans cooler leak. The radiator would need to be replaced or the trans cooler in it needs to be bypassed and plugged.
  4. #4 Re: Stepdad
    Ontario
    Removed it. Didn't mean to misinform.
  5. #5 Re: Stepdad
    Feb 2013
    Minnesota
    Grand Rapids MN Whatever is in the coolant is black.
  6. #6 Re: Stepdad
    Feb 2013
    Minnesota
    The coolant looks black and thick. I am having it flushed tomorrow. but trying to figure out how it got contaminated.
  7. #7 Re: Stepdad
    Feb 2013
    Minnesota
    He had the oil changed, a few days ago, and nothing was said about any antifreeze in the oil... so that really puzzled me. And if there is no ports in the intake manifold, the trans cooler in the radiator sounds like it could be the culprit. Then the transmission should be contaminated also.
  8. #8 Re: Stepdad
    Well if someone mixed green coolant with dexcool, it will turn brown/black.
  9. #9 Re: Stepdad
    Feb 2013
    Minnesota
    I will have to check the trans level and see what color the fluid is, hopefully no green in it. but it would stand to reason that when he had the oil changed they would have checked the trans fluid and pointed out any problems.
  10. #10 Re: Stepdad
    Feb 2013
    Minnesota
    that may be the case. Any way my wife is taking it to a garage tomorrow, maybe they will confirm that.
  11. #11 Re: Stepdad
    Feb 2013
    Minnesota
    Thanks for the ideas, it has been too cold for me to stand outside and mess with this car, the trans cooler sounds like the logical solution.
  12. #12 Re: Stepdad
    Ohio
    The coolant will scoop out like blackish brown pudding if it was mixed before.
  13. #13 Re: Stepdad
    What motor do you have?
  14. #14 Re: Stepdad
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    This is what I am thinking. I have seen it before and it is a mess to get everything cleaned out.
