Thread: Couple Problems with my 06 GP
Results 1 to 18 of 18
  1. #1 Couple Problems with my 06 GP
    Aug 2008
    Indiana
    I started getting a flashing check engine light when I hit 30 mph. I was thinking it was a misfire so I changed the front 3 and the back spark plug (back furthest right) and wires. I still get the flashing check engine light but now it happens at 60mph. I am hoping if I Change the other two spark plugs it will solve that problem.
    BUT my car is also shaking while idle and while in drive. It does NOT shake while turned on in park. The belt seems like it is making a squeezing noise, but I think it is from one of the pulleys...I just don't know how to narrow it down. Also the heat recently stopped working. The air comes on but the heat is barley warm. It's been 10-30 degrees around here so I have not had a chance to check if the AC even works. Anyone have any suggestions. I think I can fix most of the problems myself. A local mechanic told me it would be 200$ to change the spark plugs and cables. I was able to do 4 and change all the wires in 30 min for 50$.
    Any suggestions?
  2. #2 Re: Couple Problems with my 06 GP
    Get the car scanned to see what cylinders the misfire is on.
    Change those other 2 plugs aswell. Hopefully you bought ac delco plugs or atleast iridiums
    Then from there we can figure out what to do next. Be it a coil pack, Ignition module etc etc.
  3. #3 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    Yeah, I am going to change the back 2 in the tightest spot this afternoon and yeah they are all AC Delco. I will go from there and get autozone to give me the error code
  4. #4 Re: Couple Problems with my 06 GP
    Where do you live in IN? Change the other 2 plugs and wires and go to autozone or advance auto and have them pull the codes they do it for free.
  5. #5 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    Schererville IN, right near Valpo, Gary etc... I'm going to autozone later this afternokn
  6. #6 Re: Couple Problems with my 06 GP
    Pennsylvania, USA
    You should also make a habit of checking/setting the spark plug gapping before installation.Usually they're fine as is but I've come across plugs with far too small of a gap.
  7. #7 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    Quote Originally Posted by nik12937 View Post
    I read about that, but idk how to do it. I just came from AdvanceAuto they checked my error codes. The only problem was cylinder 6 was misfiring, BUT I already changed the spark plug and cable for cylinder 6. Thats the back furthest right sparkplug right? The only ones I did not change were the back 2 furthest left. I am going to do that in a couple hours when my car cools down.
    Also there is smoke coming from the belt/pulleys. I can't seem to narrow down to which one. I noticed the car only shakes in drive not park and after it wobbles there is always smokes. The car does NOT always shake, it happens almost randomly upon start upon start up.
  8. #8 Re: Couple Problems with my 06 GP
    6 is the rear drivers side plug.
  9. #9 Re: Couple Problems with my 06 GP
  10. #10 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    that's what I was afraid of. I changed the 6th cylinders spark plug and cable already, but the check engine light still blinks. I still need to change 2 and 4 spark plugs and cords but idk if that will even help. What else could be the problem?
  11. #11 Re: Couple Problems with my 06 GP
    swap your coils around i had a cylinder 6 misfire and the top coil was bad. The diagram I posted has the coils wrong.
  12. #12 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    what are the coils??? The 6 things the spark plugs connect too?
    mine are like
  13. #13 Re: Couple Problems with my 06 GP
    Yeah move the top coil to the center
  14. #14 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    How do I move those? Do I need to unscrew the covers? Mine is
    6\3
    2\5
    4\5
  15. #15 Re: Couple Problems with my 06 GP
    They have 2 small bolts in each one take those out and they come off
  16. #16 Re: Couple Problems with my 06 GP
    Two 5.5mm bolts
  17. #17 Re: Couple Problems with my 06 GP
    Aug 2008
    Indiana
    Hey guys just a quick update. It ended up being the ignition coil #6, but also I discovered that the water pump was leaking and throwing anti freeze on serpentine belt and ignition coil which I think is what caused it to go bad in the first place.
    I decided to take it in this morning since I did not really feel like doing the work myself even though I know I could have changed the ignition coil fairly easy. The mechanic is charging 420$ for everything including parts+labor.
    Is that resonable?
  18. #18 Re: Couple Problems with my 06 GP
    That's outrageous
  1. Couple of problems on an '07
    By randyb in forum General Tech Discussion
    Last Post: 12-01-2011, 07:55 AM
  2. Couple Problems
    By reaper6 in forum General Tech Discussion
    Last Post: 02-17-2011, 12:38 PM
  3. I have a couple of questions about problems I ran into...
    By NineD9GT in forum General Tech Discussion
    Last Post: 05-29-2010, 04:04 PM
  4. Couple of Problems
    By mpiacent in forum Brakes/Suspension/Chassis
    Last Post: 08-31-2009, 09:43 AM
  5. Newbie has a couple problems...
    By gggromit in forum General Tech Discussion
    Last Post: 08-12-2009, 08:19 PM
