Attachment 10829
this is after 20 minutes driving highway 60mph
54f outside.
fan is all the way on my feet.
it seems like the car get hot to the quarter only when car is on idle for about 25 min.
Attachment 10829
54f outside.
Is this a faulty thermostat or just not getting hot.
on the other side. The fan isn't hot enough like it suppose to be.
mines always at the 180 mark
Bad t-stat... Replaced it and see what happens. Cheap part n easy fix.
thats were mine was at for years, but once i replaced the ect sensor it ****ed everything up and now it reads around 205-210 mark
Not likely, but could have air trapped in the cooling system if it wasn't bled properly. Would explain the low heat. Hopefully they flushed the entire system before changing to green.
And SES is the same as CEL= check engine
Your SRS light is supplemental restraint system (airbags). Might want to have that one looked into.
I have a 180* T-Stat and my car always runs around that mark, well maybe a little more but under the 1/4 mark for sure usually. But my temperature always fluctuates always did with the stock TStat and the 180*
