Need to change the blower switch for ac/heater how do I do this. thanks
Switch, as in the entire unit? Or just the part on the HVAC unit that controls the blower?
I'm not sure you can change just 1 part on the HVAC head. Pretty sure it's all or none. If you plan on changing the head then it's pretty simple. Just remove the dash surround, remove the screws holding the hvac head into the dash and then remove any wires/vac. connections on the head. Install new one and test BEFORE you put the dash surround back on. No need breaking clips by taking it off more than neccessary.
