Thread: Busted Motor
Results 1 to 11 of 11
  1. #1 Busted Motor
    Jan 2013
    Edmonton, Ab
    Hey all, I'm new here, so bear with me. I just bought a 2000 Grand Prix with the K code 3.8. It's got a broken con rod, so I'm obviously replacing the engine. I may be able to acquire a 1997 Bonneville with a K code 3.8 as well for a donor. My questions are these-has anyone here removed the engine from the top(opposite the recommended per Alldata's info) on a 2000? Also, is there major parts swapping to use the motor from the 97, if at all possible? These are both Canadian cars. Thanks.
  2. #2 Re: Busted Motor
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    welcome
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Busted Motor
    Jan 2013
    Edmonton, Ab
    Thanks, man.
  4. #4 Re: Busted Motor
    Sep 2012
    bridgeport,NY
    out the top is easy if you take the trans out with it. and the engine will need a motor mount swapped but other than that its smooth sailing
  5. #5 Re: Busted Motor
    Coil bracket and alternator brackets are different
  6. #6 Re: Busted Motor
    Sep 2012
    bridgeport,NY
    even in the bonne
    GT Level Member Utter99's Avatar
    Warsaw indiana
    I have done both through the top and bottom . A lot less fighting to just take it out of the top with the tranny . I just like to detail things when I do it . It's a personal preference really
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  8. #8 Re: Busted Motor
    Jan 2013
    Edmonton, Ab
    My preference would be to leave the tranny in the 2000, if possible. Is there enough room to get the motor out? I should mention I do have access to a vehicle hoist.
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    http://www.grandprixforums.net/showthread.php?t=47220
    Sent using Tapatalk 2 from my GS3.
  10. #10 Re: Busted Motor
    Jan 2013
    Edmonton, Ab
    Thanks, although it doesn't really address any specific vehicle. I know that the manual asks to remove engine and trans together by dropping the subframe and motor/trans together.
    Sep 2012
    Casper Wyoming
    Its the same idea for all cars with this engine/transmission setup. The write up tells you how to pull just the engine, or a couple posts later there is additional info on pulling them both as a unit. Much easier from the top for just the engine.
  1. Busted piston!!!!
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2013, 11:10 AM
  2. pcm busted need new one
    By xBlacKxGTPx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2011, 06:56 PM
  3. busted oil pan
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2010, 01:32 AM
  4. Busted!!!
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 11-08-2009, 11:14 PM
  5. Window Busted Out
    By GreenPrix in forum Off Topic Discussion
    Last Post: 12-08-2008, 09:05 AM
