I'm not exactly sure where to post this since my problems are engine or suspension specific. I have a 2005 GT with 75.5k miles. I just had 4 brand new michelin's tire installed with alignment, balance, and rotations done about 3k miles ago. The works... Anyway, prior to my car getting new tires, I started to notice, approximately @ 63k miles, a vibration coming from the right side of my car. It first occurred when my dad and I were on the interstate. I started to feel it when I would accelerate at any speed above 65 mph. At the time it would only give me this vibration in the steering wheel and gas pedal when I had a passenger in the car. NOW it's worsened and I had T.O. Haas (the company who ended up mounting and aligning my new tires) to check out my front axles and and joints. They came back and said they were decent and they should hold up until at least spring. Well, it has only been 6 weeks since I was T.O. Haas and the vibration is getting unbearable. I don't know where to start without forking out a butt load of money, which is not what I want to do. I don't feel any vibrations coming from the rear. Everything seems to come front the front when I accelerate. I can start to feel it and lower speeds around 40 mph. now. I had my tranny flushed under 20k miles ago so I don't think it's my transmission which is why I believe it has to deal with my drivetrain. New brake pads and rotors were all installed about 15k miles ago. Like I said the vibrations only come when power is given. It will vibrate on cruise as the computer adjusts the speed and it occurs when I accelerate the car manually.
I'd appreciate any tips, ideas, or suggestions to help improve my situation. I'm not the biggest car guru but I like to tinker around. I'm all for DIY if I can fix it myself but if a car lift or new drivetrain is needed then so be it I'll take it in.
Thanks!
