Where can I buy some? And do they make a real difference keeping the motor from moving as much?
zzperformance
Which mounts would you guys recommend off their site?
I made mine, buy a set from rock auto (engine, trans mount) drill a a hole in each one at either end, drain the fluid well. let dry a day or so then with a caulking gun fill with RTV caulking, (got mine at O'riellys) then let dry two weeks or so (I let mine set a month) then install
That doesn't sound all that safe to be honest. How does that hold up?
It's actually real safe..many guys do it on other platforms when solid mounts are not available.
Yep I got the idea after seeing a ton of guys on this forum do it, there is even a write on here somewhere
