Thread: how to stop headlights from bouncing
Results 1 to 7 of 7
  1. #1 how to stop headlights from bouncing
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Awhile back I put OEM headlights into my GTP, ever since they bounce, on the expressway it is really annoying some people.
    In the summer I took them out, put them back in and got them as tight as possible, it appears since then that only the right one is bouncing.
    This is driving my nuts, tried everything and they still bounce, could a mechanic help or would I just be wasting my money?
    thanks
  2. #2 Re: how to stop headlights from bouncing
    You can try the weather stripping mod under them to help stop the movement.
  3. #3 Re: how to stop headlights from bouncing
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    A lot of people don't know how the brackets go on the car its is kinda difficult to get them in properly but pull them off and look at it real close sorry its hard to explain but I go to meets all the time and fox them for people
  4. #4 Re: how to stop headlights from bouncing
    antioch ill
    there is a tab you gotta slide behind a peice of metal if im correct. i did that and the weather strip mod it worked for a while now i got bounce again
  5. #5 Re: how to stop headlights from bouncing
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    If they are OEM.... they should not bounce? I have aftermarket and the one on the right bounce a little
  6. #6 Re: how to stop headlights from bouncing
    Dec 2008
    Lawndale, CA
    Aftermarket brackets tend to bounce more that an OEM set of brackets. A little trick that helps is to wrap some electrical tape around the plastic piece that goes into the slot on the frame to make for a tighter fit. You don't need that much tape wrapped around.
  7. #7 Re: how to stop headlights from bouncing
    SE Level Member 2000supercharged's Avatar
    Aug 2012
    unitedstates
    get 3/8 vacume line from advanced or napa and cut it down the middle and slide it over the lip of the bumper and install the headlights and go readjust them and that what stopped mine
  1. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  2. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  3. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  4. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
  5. 04 GTP headlights bouncing and load rear end
    By BrianA in forum General Tech Discussion
    Last Post: 02-03-2009, 07:25 PM
