calipers from a 2001 camaro will fit the same way correct? (I got a chance to get a set from the yard)
yes. 98-02
make sure you take the banjo bolt from the brake line, you'll need it. and all bolts and hardware.
truth is you can just remove the caliper bracket bolts, and lift the whole set up and off the rotor, id break the caliper bolts loose first as they can fight a bit when off the car.
