It's not really worth the time and effort and parts search to rebuild f body calipers for the price you can buy remans for.
But if you really want to here's a link for a good how to. www.InstallUniversity.com
I just did a parts check here if I have to replace pins $8.99 (pair) and boots 12.69 (all four) plus the calipers from the yard 17.92 (pr) caliper brackets 4.98 (pair) for a total of $44.58 remans come to $107.98 (pair with bracket) I dunno it seem like you are getting one for free and then some unless the rebuild is a real bear I will check that link but thanks
ok am I missing something I can't find a caliper rebuild in that link
www.InstallUniversity.com there ya go, its easy looking.
wont work, go top left, to install docs. then scroll down to brake caliper rebuild
Thanks scotty your right does not look too bad a job just a little patience it would seem
i was pricing up a parts list and found this
Front Brake Calipers Drilled Slotted Rotors Ceramic Pads Covers Left and Right | eBay
anybody heard of these or heard o anybody using these?
i would replace the pads if those are cheap junk.
but that looks like it comes with everything you'll need minus the brake lines and the bracket bolts(but cant you reuse the stock ones?)
i stand corrected on that, your right, looks like you need the caliper bolts only and the lines, still looks like a good deal.
or tap the brackets and use the stock w body bolts.
Oh, thanks scotty
just a thought if mycars abs and tire pressure senors 97 gt does the donora car have to as well
Thank you
