Thread: Thermostat.
Results 1 to 6 of 6
  1. #1 Thermostat.
    IL
    Would the thermostat cause the heater not to work in my 2008 Grand Prix?
    Sent from my EVO using Tapatalk 2
  2. #2 Re: Thermostat.
    Nov 2012
    Madison
    You Betcha!
    could be stuck open
  3. #3 Re: Thermostat.
    Bad thermostat can reduce he amount of heat you get. What does the temp gauge say its running at? Near the middle or more towards the bottom??
    Could also be time for a heater core flush and coolant flush with a new thermostat.
    IL
    Gage stays in the middle. Had heat this morning. Didn't last night. I'm thinking coolant needs to be changed too.
  5. #5 Re: Thermostat.
    Nov 2012
    Madison
    when was the last time you had the coolant system serviced?
    maybe time for new stuff...thermostat,coolant,bleeding system of air...could be the 100% solution
    that would be the simplest
    IL
    I will get that done. Thank you
  1. bad thermostat?
    By jwhite85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2011, 12:22 PM
  2. Thermostat?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-08-2011, 08:33 PM
  3. Thermostat
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2011, 07:02 AM
  4. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  5. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
