Thread: cooler lines
Results 1 to 10 of 10
  1. #1 cooler lines
    May 2011
    winnipeg
    Does anyone know if there is a special tool to remove the guick release trans cooler lines from an 04 grand prix. From the trans and rad.
  2. #2 Re: cooler lines
    Most use a pick or small screwdriver. However someone did show me there was a tool one time.
  3. #3 Re: cooler lines
    May 2011
    winnipeg
    next question, who knows where i can buy one?
  4. #4 Re: cooler lines
    Google
  5. #5 Re: cooler lines
    May 2011
    winnipeg
    Went to a local rad shop and they sold me a really neat simple plastic tool to remove the cooler lines from the rad and trans. It only set me back
    5 bucks and it worked great. Changed both lines in about 30 mins.
  6. #6 Re: cooler lines
    Nov 2012
    Madison
    Quote Originally Posted by dlk View Post
    wonder what it looks like
    ok I give up...show us
  7. #7 Re: cooler lines
    May 2011
    winnipeg
    I don't really know how to insert a picture but if you google " jiffy tite disconnect tools" you will get the info that you need
  8. #8 Re: cooler lines
    Nov 2012
    Madison
    this?
  9. #9 Re: cooler lines
    May 2011
    winnipeg
    no, the one I got was a plastic disc with a slot to fit over the trans line but it has the same slots on the ring. Would like to be able to send picture but it says
    file is too big.
  10. #10 Re: cooler lines
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    I have the tool to remove the lines but I rarely ever use it. I removed the c clip with a pick then work the line out of the fitting. Found this to be the quickest way at removing trans and oil cooler lines. Re-install the c clip, snap the line back in and slide the plastic clip retainer back over the fitting.
  1. Cooler Lines
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2012, 02:50 PM
  2. Transmission cooler lines
    By jakeb157 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2011, 12:09 PM
  3. Transmission Cooler Lines
    By tdm571 in forum The Rant Forum
    Last Post: 02-27-2011, 07:17 PM
  4. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
