Autolite copper 605s and stock replacement wires from Autozone, O'Riellys, Advance, Napa
For wires AC Delcos are fine or PrJ or Taylor wires really whichever you prefer there not going to add any power difference.
Autolites 605
these for example?
not from this site specifically, just getting straight what part excatly
Autolite Copper Core Spark Plugs 605 - SummitRacing.com
PONTIAC GRAND PRIX ACDelco Spark Plug Wire Sets 726UU - SummitRacing.com
Yup those are it. Advance usually Carries them in stock so you don't have to order them.
AL605's, gap them at .050".
You can get either the lifetime warranty wires, or get MSD 8.5mm or PRJ 10.4mm wires.
Performance gain isn't probably anything over the standard 7mm factory sized wires, you just get to dress up the engine bay a bit.
Sd's have a 3" dp
reuse stock
You just need the dp to catback gasket.
Let's not forget a new double walled flex to replace the one that comes on the speed daddy's
Down pipe and catback is exhaust :thumbup:
Sent from my pager using Morse code. ... .. ... ....
My flex is fine
