Thread: Replacing a bad hub bearing
Results 1 to 12 of 12
  1. #1 Replacing a bad hub bearing
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Is this something easy that I could possibly tackle in a few hours or would it be better for me to just take it to a mechanic and have them worry about it? Thanks for the help in advance!
  2. #2 Re: Replacing a bad hub bearing
    Grand Rapids, MI
    Oh it's very easy Once you've done it once you can whip em off in no time.
    Just take you wheel off, put the spare on (so you can access the axle nut), bust the axle nut loose, take brakes off, and undo the 3 bolts holding the hub on and BOOM you got it off. It's really simple. And for the axle nut you want to torque it down to 110ftlb and of course your lugs at usual 100ftlb.
    Should be some info on it on the site if you look around. And I also found reading the gm service manual helpful, it's on gpona.
  3. #3 Re: Replacing a bad hub bearing
    Mar 2012
    NC
    If it's a front bearing (which I assume it is) it's really easy and takes very little time. Remove center cap from wheel. Using a 36mm socket and a big ass breaker bar, remove axle nut. Jack up vehicle and remove wheel. Remove brake caliper, bracket, and rotor. Remove 3 15mm bolts on the back of the spindle that hold the wheel bearing in. Unplug wheel speed sensor. Using a BFH, knock the wheel bearing off the car. Install is the reverse or removal. Make sure you torque the axle nut. Have fun.
  4. #4 Re: Replacing a bad hub bearing
    Oct 2011
    huntley
    Ok thank you both! This is what I should replace if when a take a curvey road at like 40ish+ mph the front passenger side makes a weird vibrating type of noise and sometimes when I go to stop with my wheels pointed to the right my brakes pulse correct? Thanks again!
  5. #5 Re: Replacing a bad hub bearing
    Mar 2012
    NC
    Potentially it is that wheel. The only way to know for certain is to check the ABS data with a scan tool for the ABS issue. I'd hate to see you replace the wrong side. I've had one side noisy and not bother the ABS while no noise and ABS going haywire on the other.
  6. #6 Re: Replacing a bad hub bearing
    Oct 2011
    huntley
    Alright thank you very much! I have already replaced my rotors thinking that was it because they were pretty beat up
  7. #7 Re: Replacing a bad hub bearing
    The bolts on the back side of the bearing are 13mm not 15
  8. #8 Re: Replacing a bad hub bearing
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Oh - and on this job, PB Blaster is your friend for getting those three bolts free...
  9. #9 Re: Replacing a bad hub bearing
    HUDSON
    A 5lb slide hammer makes quick work removing the hub from the spindle, corrosion between the hub and spindle can make difficulty, so long as your hub has the acccess hole in the flange. Clean ALL corrosion from the spindle opening and mounting surface, this can take time, be sure not to remove material though.
    After you are finished and ready to drive the car, your still not done. Go for a short, slow speed drive, maybe 4 miles, don't go over 45. Re-peat 3-4 times min. If you do a lot of slow short city driving anyway, than your ok. One thing you want to avoid is a first drive that includes a high speed, as this will heat the bearings and damage the grease. You want to "break-in" the hub bearing, excess heat from the new bearing during break-in can damage the grease and cause problems down the road in 30-50 thousand miles.
  10. #10 Re: Replacing a bad hub bearing
    3 jaw gear puller also works good for a stuck axle shaft in the hub.
    hook the jaws on the hub, then the center bolt hits the axle, then tighten the puller. it will push the shaft out for ya.
    most of the time a few good shots with a hammer will get it done tho. leave the nut on the shaft at the end of the threads, so you dont smash the threads.
  11. #11 Re: Replacing a bad hub bearing
    Thats what i use ^^^^
  12. #12 Re: Replacing a bad hub bearing
    Jan 2021
    Ohio
    Oldl thread I know, but if you have a air compressor and a air hammer a blunt punch on the air hammer pushes the axle out of the bearing center nicely also.
  1. Did my wheel bearing/hub got messed up?? after removing and replacing
    By Haulero in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 03:25 PM
  2. Replacing Wheel Bearing
    By Pure2sin in forum How To Write-Ups/Tech Tips
    Last Post: 10-24-2011, 03:56 PM
  3. Replacing front hub/bearing
    By SnowDrift in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 05:20 PM
  4. Replacing Front Bearing/Hub
    By TMC in forum How To Write-Ups/Tech Tips
    Last Post: 01-13-2009, 01:13 AM
  5. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
