Thread: Amplifier Power Cable Routing???
Results 1 to 8 of 8
  1. #1 Amplifier Power Cable Routing???
    Jul 2012
    VA
    I'm sure there are plenty of GP's on this forum running stereo systems. I am inquiring on where you ran your power cable? I am not installing a sound system amp, but rather a CB amp behind the passenger seat on the floor. This is where I need my power cable run to. Are there any reasonably accessible holes in the firewall that will accomodate a 4awg power cable through it? If not, what is the best solution to get power where I need it? Drill a hole in the floor and grommet/silicone seal it?
    Thanks in advance!
    Pix are always good.
  2. #2 Re: Amplifier Power Cable Routing???
    Houston
    There are many many threads on this already
    http://www.grandprixforums.net/searc...archid=1018622
  3. #3 Re: Amplifier Power Cable Routing???
    Yoga city
    what year car? if 04+ driver side gromment, if 97-03 passanger side whole in firewall.
  4. #4 Re: Amplifier Power Cable Routing???
    Jul 2012
    VA
    Oh yeah sorry it's an '01.... What is the approximate location of the hole you speak of?
  5. #5 Re: Amplifier Power Cable Routing???
    Houston
    Down by the power steering reservoir.
  6. #6 Re: Amplifier Power Cable Routing???
    Right here
  7. #7 Re: Amplifier Power Cable Routing???
    Jul 2012
    VA
    Magnificent. Thank you!!!
  8. #8 Re: Amplifier Power Cable Routing???
    Np man..
    Once you are in the engine bay..tuck it behind the coolant overflow and tape or tie it off to the main loom that is right there. That way you won't pull a Jordan and have it get chewed by a belt etc.
  1. Power steering hoses routing 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2011, 03:43 PM
  2. Looking for info on 08 gxp amp power wire routing
    By chaverluk in forum Introductions/Noob Questions
    Last Post: 04-09-2010, 10:38 AM
  3. Please help with power cable for amp
    By blazer2002 in forum General Tech Discussion
    Last Post: 06-05-2009, 05:54 PM
  4. power cable from batt
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:15 PM
