Thread: Key Fob Issues - 2005 Grand Prix GT
Results 1 to 6 of 6
  1. #1 Key Fob Issues - 2005 Grand Prix GT
    Mar 2012
    Hello everyone. I've got a 2005 Pontiac Grand Prix with keyless entry issues. The battery is good, but the only button that works on the remote is the trunk button. What am I missing here? New battery didn't fix it. Any thoughts?
    Thanks!
  2. #2 Re: Key Fob Issues - 2005 Grand Prix GT
    the cover part where the buttons are wears out. sometimes you can open the case up, clean the contacts and it will work again. or order a new button pad, they run about 5 bucks new on ebay.
  3. #3 Re: Key Fob Issues - 2005 Grand Prix GT
    Mar 2012
    Thanks for the reply. I thought that could be it, but I thought the chances of all the buttons but just one failing at once was slim.
  4. #4 Re: Key Fob Issues - 2005 Grand Prix GT
    i had the same problem, it would un lock, but not lock. new button pad fixed it up.
    theres also a how to repair the pad, all you do is glue some tin foil to the buttons, and it makes a better contact.
    inside on the underside of the button is a pad it has metal paint on it, it either gets dirty or wears off.
  5. #5 Re: Key Fob Issues - 2005 Grand Prix GT
    Mar 2012
    Genius! Thank you! I took the button pad out and used foil tape and cut little pieces out and put them in there. Worked perfectly. Thanks again!
  6. #6 Re: Key Fob Issues - 2005 Grand Prix GT
    Nov 2012
    St Louis Missouri
    I had this same problem but found that if I hold the lock button for about 5 seconds, it locked. How do I take it off delayed lock? I have already set the DIC setting to "off".
    thanks!
  1. 2005 Grand Prix
    By 2005GrandPrix in forum Members Rides
    Last Post: 06-15-2011, 04:28 PM
  2. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  3. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
