Thread: what size for exhaust tips
Results 1 to 20 of 20
  1. #1 what size for exhaust tips
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i just ordered my new mufflers. 2.25 inlet and outlet. what size tips do i need to get in order to fit. I dont want to order the wrong size too big or too small. Dumb question. but i dont want to screw it up
  2. #2 Re: what size for exhaust tips
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    if you;re getting dual tips, i believe mine were 3in round. you can see them on my page here, http://www.grandprixforums.net/velic...s-4-53885.html
  3. #3 Re: what size for exhaust tips
    I live here. TLSheff's Avatar
    2.25" inlet tips to bolt onto the muffler, whatever kind of ends you want. With some slight cutting you can fit a dual 4" off a corvette in the cutouts but you need some modification to make them fit right. 3.5" duals are usually perfect fits and can be had on Ebay for around $100 pair, unless you can find a good deal.
    2 STAINLESS STEEL DUAL EXHAUST TIPS PAIR 3.0 3.5 Camaro Trans Am 3" 3.5" Mustang | eBay
    Yonaka Universal Dual Angled Stainless Steel Exhaust 3.5" Tip Dodge Challenger | eBay
    Either should work well.
  4. #4 Re: what size for exhaust tips
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    Where did you get them?
  5. #5 Re: what size for exhaust tips
    Nov 2011
    Indiana
    personally, i'd go with the slanted/angled tips. mine are straight vertical, while they look nice, the angled ones will be more flush with the bumper. make sure they're not sloppy either, nothing is more of a turn off than even tips that stick out 5 feet
  6. #6 Re: what size for exhaust tips
    Sep 2012
    Illinois
    Has anybody put a magnaflow setup on there car? If so is there a real difference or r u just paying for a name! Thanks
  7. #7 Re: what size for exhaust tips
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    You can get tips cheaper for a set. I got these and i think they fill the cutout perfectly and only about $65 for both. New Exhaust Tip Polished Full Size Truck Dual GMC C1500 K2500 Grand Am Prix | eBay
  8. #8 Re: what size for exhaust tips
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I got 4" slant cut tips on my car, they look rather fine and fits the cut out well.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  9. #9 Re: what size for exhaust tips
    SWPA
    Are you guys welding the tips on, or just clamping them?
  10. #10 Re: what size for exhaust tips
    Jan 2012
    New York
    I had my old pig snouts cut off then the new ones welded on.
  11. #11 Re: what size for exhaust tips
    michigan
    I have the ebay 3.5" duals on mine. Great look imo. Had to trim a little bit of the exhaust opening in the rear bumper to make them sit in as far as i wanted, but not a big deal at all. Def good quality and worth the 100 dollhairs!! (Pics in link in my sig.)
  12. #12 Re: what size for exhaust tips
    i really like those tips lishap.. are those exact fit? can i clamp those or do i have to weld them on?
  13. #13 Re: what size for exhaust tips
    Okay so these are the mufflers i just bought Dynomax Super Turbo Muffler 2.5" Off In 2.5" Off Out 17662 | eBay and these are the tips i want New Exhaust Tip Polished Full Size Truck Dual GMC C1500 K2500 Grand Am Prix | eBay Will this work or will the fittings not be right?
    Ohio
    Why did you buy the wrong size?
  15. #15 Re: what size for exhaust tips
    i did?
  16. #16 Re: what size for exhaust tips
    michigan
    For the tips you shouldve bought 2.75" inlet or so. You can prob take them to an exhaust shop and have them flare out the inlet tube so itll slide over your 2.50" outlet on your new muffler. My mufflers were 2.25" in/outlet then we flared those out to fit over the 2.25" stock pipe. ( might be the wrong measurements, but you get the idea).
    Ohio
    Yes you did, you need offset in, center out..
    No, if he bought 2.25" inlet tips, then he's fine
  18. #18 Re: what size for exhaust tips
    Slower, Lower Delaware
    I bought those 3.5 tips for mine. I had to buy adapters to clamp them to the exhaust. Good quality, I'm very happy with them.
  19. #19 Re: what size for exhaust tips
    Jan 2012
    New York
    For my stock exhaust they were able to to just be welded on.
  20. #20 Re: what size for exhaust tips
    Ontario
    2.25 inlet, with a 3.5 outlet. I have duals like that, and they fit perfectly. Also, get 'em welded if you have new mufflers as well.
  1. Would exhaust tips from an 04+ fit the 97-03?
    By firstdue in forum General Grand Prix Discussion
    Last Post: 05-25-2012, 04:03 PM
  2. Exhaust tips
    By tyv193 in forum Off Topic Discussion
    Last Post: 08-03-2010, 09:43 AM
  3. Exhaust tips
    By VejGTP in forum 04+ Specifics
    Last Post: 04-24-2010, 02:25 PM
  4. Exhaust or Tips...what should I do?
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-10-2010, 02:55 PM
  5. Exhaust Tips
    By SlowPurpleGTP in forum Visual/Body Modifications
    Last Post: 05-16-2008, 08:34 AM
