Thread: new eaton rotor pack
Results 1 to 9 of 9
  1. #1 new eaton rotor pack
    Kemmerer, Wyoming
    I noticed eaton is producing new rotor packs for the gen 3 blower. the advantage is that they have the gen 5 coating on them. I was wondering how much more flow these will allow and maybe be able to drop a pulley because of more flow.
    also would these be a pain to replace yourself?
  2. #2 Re: new eaton rotor pack
    Wouldn't more/better flow mean you wont have to drop pulley size?????????
    Just a thought.
    And replacing the rotor pack is simple, unbolt the snout and remove them and replace.
  3. #3 Re: new eaton rotor pack
    Kemmerer, Wyoming
    I see what you are saying. I was thinking if you had more flow then you could drop a pulley size.
  4. #4 Re: new eaton rotor pack
    GTP Level Member buickman104's Avatar
    NYC
    Would probably be cheaper to buy a gen 5 off another member or junkyard than buying a brand new 3rd gen rotor pack from Eaton.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: new eaton rotor pack
    Jan 2012
    Philadelphia
    yea thats what i would say just buy a Gen 5 there getting cheap enough now anyway
  6. #6 Re: new eaton rotor pack
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Im selling a Gen V if you're interested
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  7. #7 Re: new eaton rotor pack
    Jan 2012
    Philadelphia
    i have one, not sure if your talking to me though lol
  8. #8 Re: new eaton rotor pack
    Kemmerer, Wyoming
    I already have a gen 5. I was just curious about the new rotor pack with the gen 5 coating. I just havent put the gen 5 yet.
    Quincy, Mass
    The gen 3 rotor pack with the new coating is just that, a new coating. The rotors are exactly the same other than the new, more durable coating on them. They won't flow any better than the old gen 3 rotor pack.
    No more GP 04 Impala SS Indy:
  1. lightweight rotor pack...
    By mskram1 in forum General Tech Discussion
    Last Post: 03-02-2012, 02:51 PM
  2. Rotor Pack Bearings
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 05:13 PM
