Thread: Door handle stuck, inside passenger side
Results 1 to 5 of 5
  1. #1 Door handle stuck, inside passenger side
    Aug 2012
    Oklahoma
    Anyone ever hear of this issue before? Door handle stuck, inside passenger side. Can't open the door from the inside. I told my son that could come in handy if he hauls girls around . . . wifey was not pleased. Oh well, another door panel to remove.
  2. #2 Re: Door handle stuck, inside passenger side
    St. Louis
    Sounds like the rod has popped off the handle if this is the front passenger door. If its the rear door (on a 4 door that is), then maybe the child lock is active?
  3. #3 Re: Door handle stuck, inside passenger side
    Aug 2012
    Oklahoma
    It's the rear passenger; only one that's acting up. The handle is mostly stuck; it'll move a little bit, but won't pull out far enough to release the latch. Works fine though from the ouside.
  4. #4 Re: Door handle stuck, inside passenger side
    St. Louis
    Take a look at the slot on the door once you open it, about midway down on the edge. Should be a slot for a small screwdriver to fit and move it to unlock/lock to children. Maybe your's is stuck. Try moving it between the 2 positions and then leave it in the "inactive" position and see if you can get it to open from the inside handle.
  5. #5 Re: Door handle stuck, inside passenger side
    Aug 2012
    Oklahoma
    BY golly that was it. The label was missing on that door but I saw the label on the other door. It was the child lock all the time. Well, another job well done!
  1. Driver's side outside door handle broke
    By jokyfo in forum General Tech Discussion
    Last Post: 05-06-2012, 11:10 AM
  2. 1993 grand prix coupe driver side door handle
    By joebobyoung in forum Introductions/Noob Questions
    Last Post: 12-24-2011, 10:58 AM
