Thread: Hours Per Gallon/Gallons Per Hour
Results 1 to 7 of 7
  1. #1 Hours Per Gallon/Gallons Per Hour
    Mar 2012
    Bangor Maine
    Greetings
    I was just wondering about idle fuel consumption. For example, the building i work in lacks air conditioning. During my lunch break i go out to the car and just sit in the parking lot with the ac going. Does anyone know how much fuel the 3.8L consumes idling at appx 700 RPM?
    2004 GT2
    216,000 Miles Everything original except tires
  2. #2 Re: Hours Per Gallon/Gallons Per Hour
    Thats a tough one, I doubt any real numbers could be had, unless you fixed up a fuel tank outside the car with like 1 gallon in it and waited to see how long it took a half gallon to burn off and figure it from there.
  3. #3 Re: Hours Per Gallon/Gallons Per Hour
    Jul 2012
    Chicago
    I recall reading somewhere that an L36 burns half a gallon of fuel per hour at idle.
    -Carl
  4. #4 Re: Hours Per Gallon/Gallons Per Hour
    Assuming maf reads 5 g/s at idle
    you're going to use 1 part fuel per 14.7 parts air.
    so 18 000 g/h
    then calc fuel component: ~1 224 g/ h
    specific gravity is ~.765 g/mL or so.
    so 1 605 mL/h
    for 1.6 l/h or 0.42 gallon / hour.
    If only you guys did math.
  5. #5 Re: Hours Per Gallon/Gallons Per Hour
    It's really hard on your motor to idle for extended periods of time.
  6. #6 Re: Hours Per Gallon/Gallons Per Hour
    its even harder on your engine to beat on it.
    so what is the "recommended operation condition" for an engine?
  7. #7 Re: Hours Per Gallon/Gallons Per Hour
    That is a good question.
  1. Fuel Capacity 5 Gallons SHORT! Anybody know WHY?
    By Autoworks in forum General Tech Discussion
    Last Post: 06-04-2012, 08:50 AM
  2. Fuel tank is 12-13 gallons?
    By Xanthous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2011, 11:41 AM
  3. how many gallons are our tanks?
    By k5greek in forum General Tech Discussion
    Last Post: 12-20-2010, 12:54 PM
  4. miles per gallon?
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2010, 06:59 AM
  5. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
