Thread: Top speed, governor
Results 1 to 20 of 32
  1. #1 Top speed, governor
    Aug 2012
    Pasco, WA
    Last night I got my 2000 GTP up to 125 mph before it started cutting out. I had two other guys with me and a full tank of gas. do you think it could go faster with less weight? i know there is more there but the governor definitely cut it out. what are some of your top speeds?
  2. #2 Re: Top speed, governor
    Jul 2012
    Chicago
    More weight won't affect the top speed limiter. I've had my car up to just under 130. Like 128 or so. That was after the tune. Stock limiter was 108.
    -Carl
  3. #3 Re: Top speed, governor
    Aug 2012
    Pasco, WA
    so when you tuned your car you took off the governor.
  4. #4 Re: Top speed, governor
    Mar 2012
    Bangor Maine
    best ive done is 108 and im stock all the way
    2004 GT2
    216,000 Miles Everything original except tires
  5. #5 Re: Top speed, governor
    Jul 2012
    Chicago
    Quote Originally Posted by Jordanfilbrun View Post
    Yes sir.
    -Carl
  6. #6 Re: Top speed, governor
    I hit 120 ONCE. I have no death wish so the most my car regularly see is maybe 80.
  7. #7 Re: Top speed, governor
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    my gtp has a stock pcm, ive been to 120 also.i was wondering were the limiter was.my se was at 108 as stated above.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  8. #8 Re: Top speed, governor
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Stock GTP: Limits at 125 i believe
    Stock GT/SE with 3.8: Limits at 107 or 108 i believe also
  9. #9 Re: Top speed, governor
    ^^^that sounds right
  10. #10 Re: Top speed, governor
    The Boss Iceman6669's Avatar
    Jun 2011
    126 is stock limiter on GTP
    110 on GT and SE
    2011 F-150 Yote powered
  11. #11 Re: Top speed, governor
    antioch ill
    my 2000 gtp stops at 110 it sat at that speed for about 10 seconds kinda was disapointed
  12. #12 Re: Top speed, governor
    Jun 2011
    Quote Originally Posted by Iceman6669 View Post
    110 on GT and SE
    I believe your false on the GT/SE Josh.
    I used to have a 2001 GT and i went 107 on the highway going to hudsonville. at 107ish is when it cut out, thats what my HUD was showing.
  13. #13 Re: Top speed, governor
    Jun 2011
    Quote Originally Posted by Matt Palm View Post
    0_0
    I have had my 97 WAY past the end of the speedo before.................Does your 4th gear work???
  14. #14 Re: Top speed, governor
    antioch ill
    yes it does now i wanna go get in my car and test it out only problem is that its raining and it would be a little sketchy i hit 100 in the rain once will never do it again
  15. #15 Re: Top speed, governor
    Let me know when your transmission dies from going that fast.
    WOT shifts into 4th are just the best thing for it.
  16. #16 Re: Top speed, governor
    i hate these threads with a passion.
    you should all lower your limiters to 80 instead.
  17. #17 Re: Top speed, governor
    May 2012
    Burlington, Wisconsin
    I had my GTP at 126 according to HUD last week. Didn't cut out. The limiter must be higher, because I'm using a stock PCM.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  18. #18 Re: Top speed, governor
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    My GT gov is at 108
    My old GTP was at 126.
    Did this one time each. Most of the time its stupid to go that fast on a regular road. You could end up killing yourself or more importantly someone else.
  19. #19 Re: Top speed, governor
    antioch ill
    ive only hit 100 with my car twice in 2 years usually the highest is about 75 maybe 80
  20. #20 Re: Top speed, governor
    Jun 2011
    Id rather kill myself than kill someone else...
    I've hit 116
  1. 3100 Governor Removal
    By Futures Passed in forum PCM Tuning
    Last Post: 02-27-2012, 08:34 PM
  2. speed governor
    By Glider Girl in forum General Tech Discussion
    Last Post: 07-26-2011, 10:13 AM
  3. Top Speed Governor/Limitor
    By udmercy35 in forum General Tech Discussion
    Last Post: 02-07-2011, 09:18 AM
  4. Top speed WITH GOVERNOR?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 10-16-2010, 09:36 AM
  5. rev governor
    By Sabzz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2010, 07:31 PM
