Thread: Rebuilt engine?
Results 1 to 20 of 25
  1. #1 Rebuilt engine?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    Thinking about just starting fresh and getting a rebuilt 3800 s/c with a 3 year/110000 mile warrenty
    For anyone on this forum that knows my situation does that sound like a good route?
  2. #2 Re: Rebuilt engine?
  3. #3 Re: Rebuilt engine?
    Oct 2011
    I dont know your situation because you keep changing your story.
    http://www.grandprixforums.net/am-i-...tml#post862152
    Am I on your ignore list of something?
    Im pretty sure i responded to you that they were USED.
    I was not informed that they were used or rebuilt i was just told that they could either be rebuilt or used so i didn't know.
  4. #4 Re: Rebuilt engine?
    soooo you wants to get a new(ish) engine eh?
  5. #5 Re: Rebuilt engine?
    Oct 2011
    Quote Originally Posted by gtpsleeper View Post
    I don't have any real option at this point all the used ones i had failed withing 500, 200,75 miles
  6. #6 Re: Rebuilt engine?
    do you just want the car to run orrr???
  7. #7 Re: Rebuilt engine?
    Oct 2011
    Yes i just want it to run at stock specs ext series 2 s/c without knocking right away and i already did all the bull**** they told me to check and nothing
  8. #8 Re: Rebuilt engine?
    whats wrong with the engine as it is now?
  9. #9 Re: Rebuilt engine?
    Oct 2011
    3rd replacement engine and its rod knock my only idea is maybe dexcool is killing it
  10. #10 Re: Rebuilt engine?
    dexcool would have nothing to do with that...
    Personally, I would have it rebuilt by someone you know can do it. You might have to spend a little more but its a lot better than buying a used one and rolling the dice. You could always get a crate engine from zzp if you had to aswell...
  11. #11 Re: Rebuilt engine?
    if your not getting a warranty with these used engines, its time to start shopping else where.
  12. #12 Re: Rebuilt engine?
    Oct 2011
    They don't cover labor, labor cost more than the used engine itself....
  13. #13 Re: Rebuilt engine?
    true that, but a engine hoist and a pretty simple tool set, you can pull it yourself for a lot less. hoist rentals are under 100 bucks a week.
    maybe this shop should be testing these engines before they are just slapped in, like a good old compression test, that can be done with the engine out of the car.
    hell ive seen people use the rafters in the garage and a come along, tow truck hoists, fork lifts, theres all sorts of ways to lift a engine out.
  14. #14 Re: Rebuilt engine?
    Oct 2011
    Warrenty void if not installed by a certified mechanic.
  15. #15 Re: Rebuilt engine?
    If these are being installed correctly, programming is correct...then I can understand one or two. Not three or four. Sorry to say, but likely your new rebuilt motor would suffer the same death soon after. Something else is going on here.
  16. #16 Re: Rebuilt engine?
    Quote Originally Posted by RideWithPride View Post
    we dont have that problem here, you buy it you have a warranty, done. its junk yard engine, why in the world would it have to be installed by a certified mechanic.
    3 dead engines in a row, i for sure would want my money back, and then go shopping else where.
    you dont know me, but i would be up the junk yard owners ass demanding satisfaction. threats of law suits work well too. make sure you have all your paper work form each engine.
    in the long run, the guy at the yard dont want to go to court because that will cost him more than trying to make you whole.
    if you have to call the cops and make a report at the very least, charge him with fraud. that will get his attention.
  17. #17 Re: Rebuilt engine?
    Oct 2011
    Programming? would i change my pcm or have it reset? if so how?
  18. #18 Re: Rebuilt engine?
    Oct 2011
    The engines were refunded but let me tell you the labor was not and even though we got a real good deal on the labor it still adds up, the biggest problem to me is the time consumption, 1st engine took 1.5 months to get in, 2nd like 1 month and 3rd was 3-4 weeks i can't walk everywhere but danm im getting good at it.
  19. #19 Re: Rebuilt engine?
    a engine swap take less than a day, your doing it all wrong, well the shop is anyway...thats some major BS. 1.5 months to do a swap that is. even 3 weeks is to long.
  20. #20 Re: Rebuilt engine?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    DO NOT BUY YOUR OWN ENGINE! Take the car to the shop and tell them to buy an engine. They buy a crap engine, it's on them. That is your fault for buying crap engines and having someone else install them. You won't get labor refunded when they use your parts. SERIOUSLY!
    GPONA #1 Cyber Bully
  1. New rebuilt engine rod knock sound only 75 miles broken in
    By RideWithPride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2012, 06:18 AM
  2. Rebuilt engine wont read boost
    By GreenGTP91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2012, 02:49 PM
  3. Rebuilt top end
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2011, 08:27 AM
  4. engine rebuilt kits
    By yellow600r in forum General Tech Discussion
    Last Post: 12-19-2010, 11:21 AM
