Thread: Help a girl out! Car won't start!
Results 1 to 16 of 16
  1. #1 Help a girl out! Car won't start!
    Jul 2012
    Port St. Joe, Florida
    I bought a 1997 Grand Prix GTP about a month ago. The car had 109,000. 2 days ago, it cut off while I was driving it, then it crunk right back up. Yesterday, it did it twice and the check engine light came on. Today, it won't crank at all. I was told by the previous owner that he had replaced the plugs and wires, coil packs, fuel filter and the lower manifold gasket.
  2. #2 Re: Help a girl out! Car won't start!
    So turns over but wont fire and run?
    Do you have any way to get the code for the check engine light?
    And I have a strong hunch on the crank sensor being bad, because its a well known cause of the car stalling at random while driving.
  3. #3 Re: Help a girl out! Car won't start!
    Jul 2012
    Exactly, it turns, but just won't fire. With it being stuck at my house, I have no way of getting it anywhere to get the code.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Did you happen to see if the tachometer did anything funny right before the car shut off? My first guess is a cam or crank sensor issue.
    This post brought to you by.....
    For all your 3800 needs:
  5. #5 Re: Help a girl out! Car won't start!
    Mar 2012
    NC
    Sounds like a crankshaft position sensor to me. You're probably going to have to get it towed unless you know someone who can scan it.
  6. #6 Re: Help a girl out! Car won't start!
    Jul 2012
    Yes, the tachometer completely stops working
  7. #7 Re: Help a girl out! Car won't start!
    Ohio
    yeahhh, it be the ckps
  8. #8 Re: Help a girl out! Car won't start!
    Texas
    Do you hear the fuel pump priming when the car is turned to the on position?
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: Help a girl out! Car won't start!
    Jul 2012
    I did not pay attention to the fuel pump, I will listen for that when i get home.
    Orange County, NY
    Quote Originally Posted by Janah Strickland Yarrell View Post
    Bingo. Crankshaft position sensor is your problem. Also make sure to inspect the wore harness that goes to it. Sometimes it gets loose and hits the serpentine belt.
  11. #11 Re: Help a girl out! Car won't start!
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Post what city you are in and maybe someone local will scan it for you.
    1997 Red GTP 182000 miles stock
  12. #12 Re: Help a girl out! Car won't start!
    Guys..keep in mind the question wasn't asked if the tach drops to zero after the car stalls or before.
    If it drops to zero when the car stalls, that's normal and expected for a non running engine. If you see it act funky or hit zero with it running, that is typically the crank sensor.
    Orange County, NY
    Well, I assumed the op wasn't a complete idiot, and would understand that the tach will drop to 0 if the engine is not running.......
  14. #14 Re: Help a girl out! Car won't start!
    You and I both know when typing.. we can lose a lot of info unless it's clearly stated.
  15. #15 Re: Help a girl out! Car won't start!
    Jul 2012
    Thanks, you guys are the best! After putting it on the computer, it was the crankshaft position sensor! My car is back to normal! I appreciate all your responses. I'm sure I will be needing y'all again!
  16. #16 Re: Help a girl out! Car won't start!
    Mar 2012
    NC
    Glad you got it fixed. We're here to help whenever needed.
  1. What you should look for in a girl
    Last Post: 04-01-2011, 04:43 PM
  2. Another New Girl
    By deamwilliams in forum Introductions/Noob Questions
    Last Post: 03-15-2011, 07:12 PM
  3. New Girl.
    By MissChelsea in forum Introductions/Noob Questions
    Last Post: 03-14-2011, 05:20 PM
  4. New girl here
    By katesgrandprix in forum Introductions/Noob Questions
    Last Post: 10-19-2009, 11:32 AM
  5. New girl!
    By pontiacchantel in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 09:57 PM
