Thread: Cheapest way to a low 13's GTP?
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Cheapest way to a low 13's GTP?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    What is the cheapest route to take to get mid-low 13's for a 98 GTP?
    (Not rigged though, needs to be a reliable DD)
    All feed back is appreciated.
  2. #2 Re: Cheapest way to a low 13's GTP?
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Nitrous
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  3. #3 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    But then i'd be buying new pistons.....
  4. #4 Re: Cheapest way to a low 13's GTP?
    Florida
    "Cheap, Fast, Reliable. you can only pick two!"
    to be fast and safe you will need to spend some $$ Here is my suggestion:
    -Gen V and North star TB
    -Full Size IC with a quality pump and FMHE
    -Cam
    -L76 springs
    -and other little items to keep everything safe, not to mention work for the trans.
    -Headers
  5. #5 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    Quote Originally Posted by Z34Phoenix View Post
    -Cam
    -L76 springs
    -Headers
    Correct me if im wrong but i thought Full size IC were well over 1,000$
    and isn't a gen v a little below that as well?
  6. #6 Re: Cheapest way to a low 13's GTP?
    safely modding your car thread, read that.
    Headers, 3.4 pulley, intake, plugs and wideband tune, easy 13's
  7. #7 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    2000 Grand Prix GTP *15.11* 1/4 Mile - YouTube
    I know this doesn't seem right but it made the car slower? 16's
  8. #8 Re: Cheapest way to a low 13's GTP?
    Read the comments.
    It was atleast 100º outside and he had mad KR issues.
    Think 70ish outside with a REAL wideband tune and 13's should be easy if you can drive.
    Where you are at on the sea level scale will also determine your times.
  9. #9 Re: Cheapest way to a low 13's GTP?
    Troy OH
    buy mine, put a non-leaking radiator in it, and tune. should go low 13's
  10. #10 Re: Cheapest way to a low 13's GTP?
    Apr 2011
    Vassar, Mi
    mods in Sig, 13.33 on unprepped asphalt track with no vht. On et streets though, ran 13.45 on my dd street tires the same day
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  11. #11 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    Read the comments.
    So 3.4, sd headers, open cone? , and plugs + tune will give me high 13's?
    1. i heard you shouldn't change your plugs since there is only a 1% fail rate, but if you insist which plugs?
    2.open cone or fwi?
    3.Where do i get a tune specific for my mods on my car? By doing it your self run a big risk of ruining your car/performance?
  12. #12 Re: Cheapest way to a low 13's GTP?
    Quote Originally Posted by RideWithPride View Post
    Seriously?
    If you know what your doing you will be fine with nitrious.
    Headers, 1.9 Rockers, vavle springs, 3.4, tune. 13s For about $1,200 or less
  13. #13 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    Quote Originally Posted by Drunkie View Post
    Seriously?
    Nitrous....SAFE?
  14. #14 Re: Cheapest way to a low 13's GTP?
    Out West
    Cheap, Reliable, Fast.
    Pick two.
    Whine with your Cheese?
  15. #15 Re: Cheapest way to a low 13's GTP?
    Jan 1970
    Maquoketa, Iowa
    Ethanol
  16. #16 Re: Cheapest way to a low 13's GTP?
  17. #17 Re: Cheapest way to a low 13's GTP?
    new britain, ct
    im with bio.
    go cam, headers, 3.4, open cone, tune and run mid to low 13's.
    07 Black GXP.
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Subscribed for Lulz when ppl start getting buthurt
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  19. #19 Re: Cheapest way to a low 13's GTP?
    Oct 2011
    Quote Originally Posted by ctracer View Post
    im with bio.
    Iv'e read up a ton on cams for GTP's(3800) and the biggest issue seems to be boost bleed, which one has the best hp/non bleed gain?
  20. #20 Re: Cheapest way to a low 13's GTP?
    Florida
    lower boost is actually good. some people are mad when they do a cam and see lower boost... what they dont understand is the engine is using more air... so less pressure it built up. I would rather have Zero boost and use all the air then have 20lbs and not make nearly as much power.
  1. Cheapest harness for radio
    By newmarket23 in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2012, 09:53 AM
  2. Cheapest Roof Rails
    By Gtpboi305 in forum Visual/Body Modifications
    Last Post: 01-22-2012, 01:27 AM
  3. cheapest turbo?
    By pixel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2011, 05:48 PM
  4. Cheapest scanner
    By ckrummy in forum General Tech Discussion
    Last Post: 08-08-2010, 03:41 PM
