Thread: Thermostat housing bolt
Results 1 to 9 of 9
  1. #1 Thermostat housing bolt
    the desert
    can someone tell me the size of the bolt on the thermostat housing? I know its 10mm but i mean the actual thread size and length of the bolts. I need a replacement Thanks
  2. #2 Re: Thermostat housing bolt
    i have no idea what size it is, but if you take the other bolt with you to a hardware store, you find a nut that fits the bolt you have and then you know what size it is, find the matching bolt you need now.
    GTP Level Member apierce1289's Avatar
    United States
    Quote Originally Posted by mcsddd View Post
    If you go to a hardware store with the bolt they should be able to match it up for you.
    Sent from my Droid Razr using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  4. #4 Re: Thermostat housing bolt
    There used to be a thread with this information, but I cannot find it for the life of me.
    Might have been in the FAQ section.
  5. #5 Re: Thermostat housing bolt
    I am sorry I can't help you this time. ...Fastenal makes a 4in 1 combo gauge.... It consists of a rivit gauge,internally threaded screw gauge,drill and tap gauge. It comes in very handy and you will never be left wondering what size of bolt or thread dia. metric or standard. The part # is 11121072 ....I am sure you can get the samething other places.....Scott
  6. #6 Re: Thermostat housing bolt
    Pennsylvania
    http://www.grandprixforums.net/bolt-...ead-48823.html
    Also, at Advance and I guess other auto stores, they usually have a peg board with labeled threaded holes and studs of varies sizes and coarseness of thread and it makes it really easy to figure out what it is.
    Mine has that anyway, makes it a breeze matching up bolts and nuts
    Sport Edition Kv5 18x8
  7. #7 Re: Thermostat housing bolt
    That thread lists the head size,not the thread size and pitch.
  8. #8 Re: Thermostat housing bolt
    Ohio
    if its any help to you, my housing only has one bolt holding it down. no leaks at all
  9. #9 Re: Thermostat housing bolt
    May 2008
    GM Part Numbers 24505628 and 11508040
    Size M8x1.25x25
    I used ARP 661-1002 bolts with 12 point heads and they fit perfectly.
  1. Thermostat housing gaskets
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2011, 03:54 PM
  2. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  3. thermostat housing bolts stripping my sockets..help!!!
    By dmahlikGT in forum General Tech Discussion
    Last Post: 10-16-2010, 03:34 PM
  4. Replies: 8
    Last Post: 10-05-2010, 08:57 PM
