Thread: design flaw 04+, folding back seat
Results 1 to 18 of 18
  1. #1 design flaw 04+, folding back seat
    May 2008
    Winnipeg, MB
    The split 60/40% back seat is backwards. The smaller section should be on the passenger side so when a long object is placed in the car and the back seat is down and the passenger seat is also down its still possable to have two ocupents in the back seat instead of just one. I discovered this issue when putting a area rug in the car and wanted to put part of it in the trunk and still have the baby seat in the middle and wife beside the baby in the back seat. That would not work because of how the back seat is set up.
    2007 Pontiac Grand Prix
  2. #2 Re: design flaw 04+
    London Ont, Canada
    yeah, especially with the front fold down, would want to put everything in pass side only.
  3. #3 Re: design flaw 04+
    Jun 2011
    lol yeah!
    Ohio
    It's still better than the pissant opening in the 6th gens
  5. #5 Re: design flaw 04+
    London Ont, Canada
    ultra useless pass thru
  6. #6 Re: design flaw 04+
    May 2008
    Winnipeg, MB
    I wonder if there is a way to switch them around?
    There is only one bracket that would need to move, cut it out and weld it into place again.
    The bracket would need to go above where the hook is for the center child seat on the passenger side.
    So far I think its possible with a very fine cutting tool. What would be best way to do that?
  7. #7 Re: design flaw 04+
    GTP Level Member
    Nov 2011
    Kansas
    You guys think too much...
    Pass through problem fixed!!
  8. #8 Re: design flaw 04+
    HUDSON
    Must have been designed by the same team of twenty engineers that designed the cup holders on the 97-03 GP.
  9. #9 Re: design flaw 04+
    London Ont, Canada
    or who designed the WHOLE car to be taken apart with a 10mm 13mm 15mm socket set lol
  10. #10 Re: design flaw 04+, back seat
    Jun 2011
    Took half the engine apart yesterday with a 10mm. lol
  11. #11 Re: design flaw 04+, back seat
    May 2008
    Winnipeg, MB
    Does anybody think this could be done?
  12. #12 Re: design flaw 04+, folding back seat
    HUDSON
    Anything can be done, it is just a matter of spending the time and money to do it.
  13. #13 Re: design flaw 04+, folding back seat
    London Ont, Canada
    i look at the seats when i was installing my sub..
    as far as switching them goes, its possible, they are just bolted onto a rail for rotation.
    however its the catches/release cord thats the issue, the release could be extended, its just aircraft cable. but the location of the catches would need to be drastically altered to make them work. I would say easier to alter where it clicks in on the back, Not on the seat itself.
    Next time I've got the seats down ill take a few pics come up with some ideas. Id say it is possible, but not as easy as just switching them
  14. #14 Re: design flaw 04+, folding back seat
    May 2008
    Winnipeg, MB
    maybe its not necessary to lock the seat back in position? unless it would flip open on its own while driving then that could be annoying
  15. #15 Re: design flaw 04+, folding back seat
    Omaha, NE
    Unless the seats are "loose" They should fit tight and the latch shouldn't be necessary. That being said, if something is in the trunk and you slam on the brakes without the back seats being latched, don't complain when you get knocked out. Have you looked into swapping your back seats for some from another vehicle? Might be easier than all the fab work.
    Its funny that you call it a design flaw, at one point it was seen as a design advantage, much like the 90* doors.
  16. #16 Re: design flaw 04+, folding back seat
    May 2008
    Winnipeg, MB
    Am I the only one that thinks it would be nice to retain at least two seating locations instead of just one when transporting something really long inside the car? Solution, switch the narrow and wide seat backs around. Also if something slides from the trunk it should be stopped by the back of the front seats.
  17. #17 Re: design flaw 04+, folding back seat
    London Ont, Canada
    i would say you do need latches, its a given.. i do also say it would be better to have the skinny side on the side with the front fold down seat.
    today is car day for me so ill at them and see what could be done
  18. #18 Re: design flaw 04+, folding back seat
    SWPA
    Quote Originally Posted by tod1d View Post
    You're the only one. If you are getting something long the solution is to not have any passengers.
    Its not a flaw. Its as it was supposed to be designed. If you have a long object that has to go all the way to the front, that also happens to be a little wide then it needs to go on the passenger side because the driver should not be affected.
  1. Belt Question, 1st design or 2nd design?
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2012, 01:10 PM
  2. 1st Design or 2nd Design Water Pump?
    By BlackGT1 in forum General Tech Discussion
    Last Post: 04-22-2012, 11:16 PM
  3. Cam design
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 05:26 PM
  4. Sub box design
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2009, 02:10 PM
  5. SRT Design
    By flash527 in forum Track Sessions and Kills
    Last Post: 07-22-2009, 06:27 AM
