Thread: crankshaft position sensor
Results 1 to 15 of 15
  1. #1 crankshaft position sensor
    Jun 2010
    canada
    I got a code po336 ,my question is where exactly is this sensor
  2. #2 Re: crankshaft position sensor
    Houston
    Behind the harmonic balancer. The balancer will need to be pulled to remove the sensor.
  3. #3 Re: crankshaft position sensor
    Jun 2010
    canada
    you said its behind the harmonic balance ok, but where is it.
  4. #4 Re: crankshaft position sensor
    Houston
    Right here is the sensors plug. The large pulley is the harmonic balancer.
  5. #5 Re: crankshaft position sensor
  6. #6 Re: crankshaft position sensor
    Jun 2010
    canada
    thanks a lot for the pictures it help a lot in identifying the unit
  7. #7 Re: crankshaft position sensor
    Jun 2010
    canada
    Could you tell me how to replace the unit in a simple way?
  8. #8 Re: crankshaft position sensor
    that write up 3 posts up is the easy way.
    unless you are referring to the getting the bolt off balance'r part. big pipe on a breaker bar works, also the starter method works, you need to take fuel pump repay out, start the car let it run out of gas, then put a breaker bar with socket on the bolt, let the bar hit the ground and then go crank the engine to break the bolt loose.
  9. #9 Re: crankshaft position sensor
    Jun 2010
    canada
    I think that you did not understand what I am was trying to say,I know that you are trying to be sarcastic,but the reason that I ask the question is because I never done any thing like this before,what are the steps to take in replacing the unit, and how difficult it is.
  10. #10 Re: crankshaft position sensor
    that how to posted is as plain English as your going to find, remove the balance'r and its behind it, not much to tell. there are pics in both posts.
  11. #11 Re: crankshaft position sensor
    This is "never done it before" guide that should help out. To give you a little more info and commentary on the procedure. The sensor is held to the block by two bolts and a pin that gives it the proper location. It's pretty straight forward, with a couple potential issues that you might run into. The balancer bolt is very tight and as Scotty mentioned there are a couple ways around this issue. I mention the bolt size in the thread because it can be tough to find, 1/4" fine thread also will work. It's just not 100% the right bolt.
    Overall if you were to see this done, you'd say it seems easy. Toughest part is getting the bolt out of the crank. After that, it's a couple 13mm bolts a plastic shield and then putting the balancer back on the crank, turning it and pushing lightly until it engages the key into the keyway, then it won't turn by hand and you tighten the bolt back on.
  12. #12 Re: crankshaft position sensor
    Jun 2010
    canada
    Thanks guys you help a lot
  13. #13 Re: crankshaft position sensor
    Jun 2010
    canada
    what about cataclean what do u know about the product? is it good to clean your catalytic coverter because every now and then I get code po420.
  14. #14 Re: crankshaft position sensor
    Neverheardofit
  15. #15 Re: crankshaft position sensor
    Jun 2010
    canada
    Neverheardofit
    I saw it on utube.
  1. crankshaft position sensor help
    By joshuasauce in forum Engine
    Last Post: 07-20-2021, 09:29 PM
  2. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  3. Replaced Crankshaft position sensor, now won't start
    By 03grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2010, 09:22 AM
  4. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
  5. Trouble History With Crankshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-23-2008, 09:43 PM
