Thread: So does anyone else have a problem with flex blades and drivers side washer sprayer?
Results 1 to 5 of 5
  1. #1 So does anyone else have a problem with flex blades and drivers side washer sprayer?
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    I feel dumb for even asking this, but I can't be the only person with this problem... can I?
    So due to the placement of the sprayer on the wiper arm the flex blade blocks most of the washer fluid on the drivers side.
    Not the passenger side, it gets dispersed quite well and cleans up nicely. However the drivers side is always slow to clean as the
    wiper has to make a pass or two just to get the fluid on the windshield.
    So am I the only one with this problem?
    And if not has anyone solved it? I've tinkered with it a tad, but no real solutions.
    So if anyone has a good solution please lay it on me, I'm all ears, and no I'm not going to get rid of the style of blade, I like to much.
    Thanks
    Drew
  2. #2 Re: So does anyone else have a problem with flex blades and drivers side washer spray
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Is this a specific brand of flex blade? Every brand I've seen likes to have a different hookup, some bulkier than others.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  3. #3 Re: So does anyone else have a problem with flex blades and drivers side washer spray
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Not only that but the set of flex blades I had liked to lift from the window at high speeds, say about 80mph or so. after switching black to good ol' Michelin blades with the scaffolding I'm not sure why I ever went with flex's
  4. #4 Re: So does anyone else have a problem with flex blades and drivers side washer spray
    Jefferson City MO
    I'm using RainX latitudes, never had a problem with them lifting, what brand were you using addzradd?
    Drew
  5. #5 Re: So does anyone else have a problem with flex blades and drivers side washer spray
    Feb 2010
    Cleveland
    Trico's IIRC
  1. Wet Seatbelt - Drivers Side
    By talladam in forum General Tech Discussion
    Last Post: 10-26-2011, 08:08 PM
  2. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  3. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
