Thread: Removed the resonator from my 08 gxp
Results 1 to 14 of 14
  1. #1 Removed the resonator from my 08 gxp
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    https://www.youtube.com/watch?v=opUc...e_gdata_player
    Sent from my HTC Flyer using Tapatalk
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  2. #2 Re: Removed the resonator from my 08 gxp
    Apr 2012
    michigan
    what did you do, just put a strait pipe on it? what else have u done to your gxp i have a 07 looking for mods. and to stop oil consumption
  3. #3 Re: Removed the resonator from my 08 gxp
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    hmmm sounds just alright
    Jul 2010
    Detroit
    Sounds better in person... They welded a straight pipe on in place of the resonator...
    Ryan
  5. #5 Re: Removed the resonator from my 08 gxp
    Houston
    Weird. My GTP sounds just like that. Res deleted with a 3" straight pipe welded from that cat back to the Y
    Jul 2010
    Detroit
    None of my mods are really mods... Just a couple of visual changes.
    Ryan
  7. #7 Re: Removed the resonator from my 08 gxp
    Yoga city
    oil consumption? i have yet to have an issue there
    Jul 2010
    Detroit
    Yea idk if it sounds just like mine, but it does sound better than my gtp with res delete, and magnaflow mufflers. My gtp sounds like ****...
    Sent from my HTC Glacier
    Ryan
  9. #9 Re: Removed the resonator from my 08 gxp
    SE Level Member 07GPBase's Avatar
    Sep 2011
    Ohio
    I thought deleting the resonator caused a check engine code to pop on. Anyone know of that for sure?
    Do You Drive Excitement?
  10. #10 Re: Removed the resonator from my 08 gxp
    Kansas
    Quote Originally Posted by Jteske88 View Post
    DoD is where the oil goes. It's a known issue with the GXP with the displacement on demand crap. When the engine uses only 4 cylinder, the other 4 are still getting oil. All 8 run burns the oil in the cylinders. Only way to get around it is have it tuned and have DoD disabled. Some say they never noticed a difference in MPG, some have seen 3-4 MPG.
  11. #11 Re: Removed the resonator from my 08 gxp
    new britain, ct
    Quote Originally Posted by 07GPBase View Post
    taking off the res will not put an engine light on.
    what WILL put an engine light on is deleting the cat/o2 sensor
    07 Black GXP.
  12. #12 Re: Removed the resonator from my 08 gxp
    Sep 2011
    Ohio
    Ok cool thanks for verifying
  13. #13 Re: Removed the resonator from my 08 gxp
    Apr 2012
    michigan
    how do i disconnect my DoD
  14. #14 Re: Removed the resonator from my 08 gxp
    Yoga city
    if you unplug it you get a code, so like said above looks like it needs to be tuned out
  1. removed the door moldings
    By z3r0 in forum Visual/Body Modifications
    Last Post: 08-12-2011, 01:23 AM
  2. Help! I can't seem to get wheel hub removed...
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2009, 01:06 PM
  3. arrowhead removed...
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 07-29-2009, 11:19 AM
  4. I want a tune removed. Possible?
    By Deezul_AwT in forum PCM Tuning
    Last Post: 05-13-2008, 10:05 AM
